Scanguage data requested (TPS, engine load)
My girlfriend's TC was recently getting a P2112 error. I was fortunate to find a used throttle body for $50 versus the $900 at the dealership. I cleaned the used throttle body with a carburetor cleaner and replaced the faulty TB. When I started her car, the motor would, rev, idle, rev, idle... it continued to do this until I turned the motor off. I started it about 10 minutes later and it did the same thing until I shut it down. I tried again about 10 minutes later and the rev-idle was gone but I noticed that the idle RPM was unusually high. It was about 1500 rpm even though the car appeared to be relatively warmed up. TPS was measuring 17-18 and the LOD was a little under 20. I drove around for about 10 minutes and then came back to do some more research.
About 1 hour later, I started the car again and the RPM's dropped to an acceptable value, 700-800 RPM. However, the TPS at idle was still showing 16-18 and the LOD was similar.
Can someone please give me TPS and LOD numbers when their stock TC is warmed up and idle? If your car is modded, I will accept those numbers as well but please let me know what mods have been done to your car.
Thanks in advance.
Thanks in advance.
TRDSCIONTC06
12-31-2014 10:12 PM
