amamdani15 |
10-20-2015 07:18 AM |
Scion tC 5-speed having issues with going into gear and making whining noise
I have a 2007 scion tC and today it was running fine until all of a sudden i could no longer shift into gear. i was able to get it home by slipping into gear at the correct rpm. once i got into my garage, i tested to see if i could figure out to see what was up and had no luck. these are the symptoms.
- Clutch pedal feels normal and when i am able to get into gear, when i release it, it engages.
- There are no weird noises when the clutch is depressed and the car is in neutral.
- when i put the car into gear and the clutch is depressed, it makes a whirring and whining noise.
- i cannot shift using the clutch.
any ideas what is happening? im assuming that it is a bearing, but i have no idea, and want to have some sort of guess of what i am looking to pay for a mechanic.
