shifter squeak????
Havent Found A Direct Answer To This Solution, If Its Already Been CoveRed Please Send The Link,.............Well My Car Gives AN Annoying Squeak When The Shifter Is In Neutral And Is Moved To The Left, Also Gives Another Squeak When Shifting Into First Gear, No Squeak Os Giving When Im Driving, Only When Shifter Os Moved To The Left In Neutral And When Shifting Into First Gear,....Advice On How To MaKe It Stop Is Greatlly Appreciated, Noise Is Super Annoying, Car Only Has 38K Miles, And Squeak Started About 1 Moth Ago. Thanks
http://clubsciontc.com/forums/diy-in...ueak-fix-9916/
Try this
Sent from my SGH-T989 using Tapatalk 4 Beta
Try this
Try this
Try this
My Clutch Isnt Squeaking Thou, I Fixed That squeak, The Squeak Now Is Coming From The shifter
Maybe its the stock rubber bushings that connect the shifter to the floor. Also maybe the grease where the shifter cables connect to the shifter might need some lubrication. I haven't had this problem, hopefully you get it figured out. Doc Isotope has gt shifter cage bushings for sale.
Andreas24
Sep 15, 2015 02:10 PM
