Shimmy
There was a discussion awhile back on why my 05 tc would shimmy at around 60 - 75 mph. The wheels were scuffed a bit and one even had a bend in it. I had all that fixed and it still shimmied. I even had the wheels balanced at a race shop for high speed balance. I finally found the cause over the weekend. It was time to do the brakes and upon inspection, I found my right front caliper had a small fluid leak. Removing the caliper and then going after the slide pins, I found the pins had completely seized in place. After trying for about 2 hours to get the pins out, I used a torch, penetrating fluids, hammers, chisels, and these things wouldn't budge. I finally broke down and bought a new caliper bracket. I greased the pins up real good so they hopefully don't seize again. Anyway, taking it out for a test drive, I found that the shimmy was gone, so I believe it was because the pins were seized. Just thought I'd share this in case someone else was having troubles.
mikochu
95
Jul 24, 2017 02:48 PM
