stage 1 head package. worth it????????
I think he's talking about the ZPI stage 1 head that goes for about $550 i was woundering the same thing but i want to see a dyno first so i could see if its worth buying. And i would also like to know if its ok to have the stage one head and run the turbo because they didnt do it to there project car so it might not be a good idea. If you guys at ZPI read this can you let me know if its ok to get the head and a turbo. Thank you
I'm guessing that you're talking about the ZPI stage 1 head package. They haven’t released a dyno yet, they've only posted their claimed gains. I really want to see a (well done) dyno in order to see how their modifications to the head affect the power curve. Until then, I couldn’t really say if it will be worth it or not, and it really depends on what your goals are. For example, if all you're looking for more mid-range power, and the head package focuses on top end power at the sacrifice of mid range, then it may not be worth it to you. But we won’t know until we see some dynos.
not cracking on ZPI but all it is a port and polish... just get a local shop to do it and not worry about shipping they dont make a new cylinder head just bore it some to let more airflow in... and Hell yea its worth it... and go ahead and port and polish the intake manifold as well.
www.zpiracing.net
or
www.zeropointindustries.net
one is on his SL profile, the other is in his signature. Not sure which one works....I cant get to either of them from work, since traffic is restricted here, lol
or
No problemo.
Repeating my question, with a little more explanation....
Regardiing the port/polish head....wouldn't that require a custom header setup??? Aren't you basically enlarging the exhaust ports, and thusly, a header/manifold with larger ports would be required to mate with the head?
beuller? beuller?
beuller? beuller?
Originally Posted by ryden305
well im trying to get some more power with out exhaust. just dont want the honda sound. not sure about forced induction yet, and also about reliability. think it will gol-darn with any thing. is it high risk?
Originally Posted by toastbox
No problemo.
beuller? beuller?
beuller? beuller?
Originally Posted by The Instigator
No. header ports will be in the same place. If it turned out that your port were larger than the primaries, a header with larger primaries would be ideal. If it was only slightly larger, you could port the header flange to match the exhaust ports.
It would be smart to do a port match so the ports on the head and the header/intake are the same size. This would allow optimal air flow.
On my old car, turbo'd corolla, I port & polished my intake manifold.. I had the intake manifold port matched to my overbored throttle body... Different scenario, but same concept.
