Stock alternator output.
Old Jun 28, 2006 | 10:57 PM
nferra2's Avatar
Default Stock alternator output.
I have searched this and other forums for the stock alternator output for the tC on this forum and other forums. I did not see a rating on the alternator itself. I have seen people saying it put out:
75
80
90
95
105
115 amps
I trust it is somewhere in that range. I don't think I will be pushing the limits of it, since my amps with only push about 700 watts RMS,
but both Amps are class a/b and fairly inefficient so if the alternator is small enough it would cause some dimming issues.
Thanks in advance.
Nick
Last edited by MR_LUV; Apr 5, 2018 at 04:51 AM. Reason: Moved to Correct Forum by Moderator
Old Jun 29, 2006 | 12:52 AM
fujitech43's Avatar
it says 1200W on the FAQ
http://home.cfl.rr.com/icdedppl/faq.html#c2
Old Jun 29, 2006 | 01:02 AM
nferra2's Avatar
So how would that equate to amps?
1200watts/14volts =approx 85 amps?
Old Jul 25, 2006 | 03:25 AM
BlueTC06's Avatar
haha 14 volts my butt ..you may get it for a second or two but the real voltage is around 12.5 and I'm basing this on my old camry but they only put like a 60 amp alt in most four cyl
Old Jul 25, 2006 | 03:49 AM
Dr_Isotope's Avatar
Between 87 and 96 amps, depending on output. My meter shows average operating voltage at 13.8v, which is an 87A output.
Old Aug 14, 2006 | 01:06 AM
engifineer's Avatar
If your electrical system is running 12.5 volts on ANY car, your battery is not charging. A 6 cell lead acid battery requires over 2.15V per cell to charge, that comes out to just shy of 13V. To be able to charge efficiently it should be in the mid 13V range. You will read 12.5V possibly right after shutting the car down, but your charging system is not running 12.5V if it is working. This goes for any car, regardless of anything else. The dependency is on the number of cells in the battery.
Old Apr 3, 2018 | 09:00 PM
digdeep0169's Avatar
so.... which Alternator comes stock??
SloTC1
Apr 2, 2015 07:11 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
lunchbx05
Dec 29, 2014 07:53 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
