Stuck Clutch
Stuck Clutch
While I was bleedig the clutch, I had someone inside the car pushing the clutch pedal in, at which time I opened up the clutch bleeder port, and now the clutch pedal will not move from its pressed in position. What did I do wrong and how I fix it?!
Its supposed to do that. Reach down, pull it up, and pump it slowly and gently until it gets pressure again, Then repeat until you dont get any air bubbles from the bleeder.
Might I ask why you are bleeding the hydraulic system on a stock clutch?
Charles
Charles
SJMiller
09-12-2015 06:33 PM
BlingSlade
09-05-2015 08:52 AM
