tC Cam gears or cam shafts available?
Do they make cam gears or cam shafts for tC's yet...I've look all over the place and can't find any online???
only one i've ever heard of was from ripp mods who made a specific trd supercharger cam. ask icenine about it.
not quite sure, but definitely watching,
I remember hearing rumors about a company that did regrinds a while back.. but I can't remember specifics..
no company makes new cams for sale that I know of for the tc |
your not going to squeeze anymore hp out of the cams N/A without going cmpletely unstreetable and even then the gains would be marginal, they are on the other hand a little limiting on the f/i side tho. But 500hp is still capable. Rippmods is your best bet. I personally do not trust regrinds, they have t be done abslutely perfect to last at all.
Cam gears? what do you think vvti is? camcon is a controller then can adjust the vvti i belive. also why do you want cams? your probably looking at near 1000$ to do cams for this motor which has no use at all unless your running 20+psi of boost or trying to build a n/a track car buy a ported polished head with bigger valves and an emanage if you want n/a power. |
Hey you might wanna call Greg down at GSC in charleston, they might be able to hook you up with something, or lead you to someone that has them.
http://www.briancrower.com/
their ad in the newest issue of Super Street says tC parts are in development (small print at the bottom of the ad) |
scion-parts.net has built some for thier racecar and rumored to have said they will release them at somepoint
Brian Crower is developing cams for the tc.
and that is nonsense about cams not doing anything for a NA tc! ;) true, they probably will make idle a bit rougher and guzzle gas. and i'm not sure how the cams will affect vvti, like if it still works or not. but you will get nice significant gains with cams. you do NOT want cams from a racer car though. :) we don't have cam gears do we? |
