TC Dry Shot 9 oz Bottle...
Has anyone seen this product? is it any good? what mods should u have to run with it?
just interested because of how small it is...
what i cant understand is how the motor wont redline if u use this... it needs a 6th sooo bad
http://cgi.ebay.com/ebaymotors/Nitro...spagenameZWDVW
the first reason to say no is its a DRY shot in other words run lean and detonate me please
2nd reson is its a no name company well not no name but i wouldnt buy any thing from them
if you realy want to cheap out and buy a dry nitorous kit rather then wet atleast get a good one
http://www.prostreetonline.com/buy/n...idden_systems/
although i have had issues in the past with prostreet so buy it else where
DAMN!!! This dude is making living off this ish!!
Nothing More Than A Paintball Co2 Bottle & Plastic Line! Sent Back, No Refund!
Buyer XXXXX( 682) Oct-28-05 06:54 8005640725
Rating Mutually Withdrawn: Buyer and seller mutually agreed to withdraw feedback for this item. Learn more.
thanks for all the support guys!!! if i was to do like a 10 lb NX bottle (wet) what mods should be done before so i dont blow it up? like i know ill be spending like 599-700 for the NX kit... but what would happen if i put the kit in with no mods. and used it just as like a spiratic extra little boost here and there? like that the only thing i want... i dont race much at all-- i need help with this! i know nothing about setups etc.
I'm going with the ZEX kit, as it's about the same price, but turns on the N2O at full throttle using the throttle position wire, instead of a microswitch in the engine bay, which I like a whole lot more safety wise...
You really should not go over a 50 shot and you should look at a wet "Fogger" kit, instead of a dry kit, as it'll be a bit safer overall... that is if your worried about your engine... you can run 75, but you'd need to be really careful.
The extras you should run is a bottle guage, to know your pressure, a safety blow down kit, a bottle heater, and a purge kit is always nice... you'll also most probably run premium fuel.... and have to run at least 1 step colder plugs to prevent problems...
It gets more detailed than plug and play.... but, this info will get you started on your journey...
WWW.ZEX.COM
For Info and Install Instructions...
Here is a simple link from google for prices... you local speed shop should be able to get one too...
You want the ZEX 82021 Univeral....
Click Here for More Info about the 82021
No problem on the info... it's what I do...
In regards to install, there is the guide on the zex website... it's a little time consuming, but pretty straightforward.... lots of running hose and wires....hardest part is probably running the wires from the selonoid box to the cabin through the firewall.... Just make sure to follow ALL the instructions and best to have someone knowledgable in N2O helping you out...
