Tsudo Mid-pipe with TRD Exhaust Problem
Old Jun 18, 2011 | 08:30 PM
VINC3TC1's Avatar
Default Tsudo Mid-pipe with TRD Exhaust Problem
I'm in the process of installing the Mid-pipe and it seems the Mid pipe is not wanting to bolt up right into the TRD exhaust has anyone experienced this before or am I doing something wrong.
Old Jun 18, 2011 | 09:29 PM
dropzone's Avatar
IDK, I've read that one aftermarket mid-pipe needed to be extended to work with some axle-backs. Is this the issue, not long enough to bolt up?
Old Jun 18, 2011 | 09:38 PM
VINC3TC1's Avatar
The issue is that the bolt holes on the tsudo will not line up right with the TRD the length is fine.
Old Jun 19, 2011 | 03:09 AM
killatc171's Avatar
i had a similar issue with mine. i could get the bolts to the point where they almost would go. basically what i did was i unbolted the piece where the 2 pieces of the midpipe connect together bolted the axleback to the back piece then bolted the 2 back together.
Old Jun 19, 2011 | 03:51 AM
Jon's Avatar
Jon
Moderator
Moderator
I had that exact set up and now I have a stock axleback with the Tsudo midpipe and no issues whatsoever.
DJ_FroZone
25
May 30, 2019 07:17 PM
mark13018
Feb 6, 2015 08:57 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
