WR header + meagan mid pipe
will the header and s pipe bolt up to the mid pipe being that they are not the same size. WR is 2.5 and meagan is 2.25. i want to know before i get the mid pipe.
thanks for the reply.
so i'll be running this set up. what do you guys think?
WR header s pipe + meagan mid pipe + tanabe concept G ax back. s/c + K&N drop in filter + 9.5 psi pulley.
do you guys think it would soung ok. i went with the tanbe b/c it is rated below 93db. figure that i'll start with that set up and if need be i'll add a resonator if i get too rasy. heard that the WR isnt that bad with rasp. i have the TRD exhaust on it now and really like the way it sounds. not too loud at all.just a low hummmmm to it. but i havent put the header and mid pip on with the TRD.
From what Ive heard, the TRD axel back sounds good by itself..... but when you add a header / s-pipe como, it really makes it raspy. I think the set you said with the tanabe axel back would be a good choice. If your looking for something really quiet, the Greddy SP2, which i have, is great. A slightly rumble at idle, barely anything under normal driving conditions, and a nice mid ranged pitch under WOT. No rasp at all.
SloTC1
Aug 16, 2018 02:45 PM
