***HELP*** Greddy Turbo install problems
Hey everyone I need your help if you have installed a turbo kit. I just got done installing mine and i starts but, it revs really high and shuts off immediately. I had it running a few hours ago with out the e manage and it idled good. Now that i installed the e manage and injectors it is falling on its face. I rechecked the wiring on the injectors and I'm pretty sure the e manage is wired up right. If anyone knows whats wrong please help
does any one know what the settings of their e manage are? I'm talking about the ***** that you can adjust including the ones behind the face plate. I've tried everything. it will sometimes turn on but when it starts to build boost then it falls on its face.
are you using a plug and play harness??? They are different. The 05-06 and the 07-08 are two totally different harnesses. I'm going to assume you have an 06, and are using a pnp harness for an 07 and in doing so you are running into a problemw with the emanage/ecu not recognizing your MAF. You need to do 1 of 2 things, get the correct harness, or take it to someone who understands the pinout and can connect the emanage correctly.
Originally Posted by beastC
are you talking about the emanage harness? My car just seemed like the fuel was being cut off at around 4000rpms
i found out what is wrong. The tune on the e manage is set for an 07 and it is completely different than an 06. I am making a support tool and i got the software from greddy and i will just download the base map for an 06 into the e manage and be all good
cessblood
Sep 15, 2015 06:50 AM
my06tc
Jun 25, 2015 12:18 AM
PTUNING
Dec 11, 2014 08:09 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
