05-06 Boosted Vs. 07-08 Boosted
why does it seem like the 07-08 tC's do much better with boost then the older tC's?
did Toyota change something in the engine ? and if so what?
aside from the different maf sensor, and a slight bump in compression, peak torque arrives 100 rpms sooner and peak hp is reached 300 rpms higher. so they do have a slightly different power band.
so 05-06
163 lb-ft torque at 4100 rpms
160 hp at 5700 rpms
07-08
162 lb-ft torque at 4000 rpms
161 hp at 6000 rpms
so 05-06
160 hp at 5700 rpms
07-08
161 hp at 6000 rpms
so 05-06
160 hp at 5700 rpms
07-08
161 hp at 6000 rpms
so 05-06
160 hp at 5700 rpms
07-08
161 hp at 6000 rpms
Re: 05-06 Boosted Vs. 07-08 Boosted
The new engine is reworked from the old engine
You have to remember that they changed the way the SAE hp ratings are applied and the 07-08 tC's are actually about 5-10hp up on the 05-06 stock, using the older rating scale
This is most likely due to the slight increase in compression, mentioned above, which is good for low boost/no boost but may not be as beneficial for high boost application.
A customer’s 07 tC with Joe's old kit made 261whp at 6psi which is pretty impressive, once again that is at low boost.
Yeah, I think it is mainly do to the higher compression, but it's not a great difference liek it is from teh celica gt to the celica gt-s, for example.
However, if you really want to up the boost, it is better to have LOWER compression to decrease chance of detonation, right?
So with lower compression, you loose a little power, but you get the ability to safely add more boost pressure which in turns gives you more power.
Not 100% true, but it gives a general idea.
Correct, for high boost levels low compression is USUALLY the way to go because as you stated you can increase boost pressure to compensate which more than cancels out the increases you would have gained from a slight bump in compression.
Increased compression +low boost = little more power
Low compression + high boost = Much more power.
We could spend all day throwing ratios around and then build the worlds best tC!
crimson_sinn
09-25-2015 09:41 PM
Threequalseven
08-26-2015 04:24 PM
