12lb s/c pulley?
Old Jan 17, 2007 | 04:14 AM
vietboinumba6's Avatar
Default 12lb s/c pulley?
how does IceNine has his supercharger to reach up to 12lb with the nst pulley?
Old Jan 17, 2007 | 04:51 AM
TheQuietThings's Avatar
does that sentence even make sense?
Old Jan 17, 2007 | 05:52 AM
let me slow it down for you, Does IceNine"311hp trd s/c" get his NST pulley to reach up to 12lbs of boost?
Old Jan 17, 2007 | 05:59 AM
05-RS1's Avatar
he requested a 12lb pulley from nst. they can make make pullies at special request too.
Old Jan 17, 2007 | 06:00 AM
hotwheelsrs1's Avatar
yes u can get nst to cut u a 12 lb. pulley for like $150, but u need management software.
Old Jan 17, 2007 | 02:13 PM
cessblood's Avatar
^^ He is right
Old Jan 18, 2007 | 03:09 AM
soros151's Avatar
Custom Made!
Old Jan 19, 2007 | 06:22 PM
krdshrk's Avatar
Yes, it was a custom made pulley. They can make them for you, but by no means should you run this without fuel management.
Old Jan 20, 2007 | 07:44 AM
tCtuner's Avatar
What kind of FM does one need to run a 12lb pulley? And, can that FM be "set it and forget it" enough to be a daily driver of say 160 miles per day?
Old Jan 20, 2007 | 01:29 PM
krdshrk's Avatar
Fuel management.. like in IceNine's car, would be GReddy Emanage Ultimate. You could probably get away with the EManage Blue. Once you get that pulley installed, you would need to be tuned. Then you can "forget it" and drive
Old Jan 20, 2007 | 04:43 PM
tCtuner's Avatar
Just so I understand you correctly, a 12 lb pulley and emanage blue would be good enough for "set it and forget it" even for a daily driver who goes 180 miles per day?
Old Jan 20, 2007 | 06:17 PM
abe_mitchell's Avatar
yes it would be enough
Old Jan 21, 2007 | 07:20 PM
HighlanderMac's Avatar
NO!!!!
It would not. You are going to need to get bigger injectors, and some type of cooling. And to keep it at 12lbs you wouldnt be looking at a air/air intercooler, you would prolly drop about 4lbs of boost.
Old Jan 21, 2007 | 09:28 PM
tCtuner's Avatar
Bigger injectors than what comes with the TRD sc? Please explain what you think I would need to run a 12lb pulley.
Old Jan 21, 2007 | 09:57 PM
soros151's Avatar
550cc injectors, engine managament, and tuning, maybe an Intercooler. Those are the things u would need.
Old Jan 22, 2007 | 03:29 AM
krdshrk's Avatar
Forget the intercooler. He's got the 12 pound pulley, 550cc Injectors, upgraded fuel pump, and Meth injection (better than adding an IC). Also tuning, of course.
Old Jan 22, 2007 | 03:48 AM
soros151's Avatar
I KNEW IT! I forgot about that. That was what i actually was thinking of.
Old Jan 22, 2007 | 04:12 AM
draxcaliber's Avatar
well, i was going to talk about www.forcefedracing.com that say call them and ask about their stage 3 11 lb psi supercharger upgrade, but that site had disapeared. shame too because they had upgraded pulleys and tuned unichips to go with them. oh well, maybe somebody else will.
also, can't you also make the crank pulley bigger to increase the boost since that would change the ratio of rotations in the serpentine belt?
Old Jul 14, 2007 | 11:58 PM
SoccerBoy_AP's Avatar
Toyota/Scion allows installation of the S/C without any internals to be changed running at 7psi.
You can get the 9.5psi upgrade pulley from NST and reading this post you can get custom higher PSI pulleys for the tC.
At what point or PSI is a internals upgrade recommended?
Old Jul 15, 2007 | 01:59 AM
usually once you get to 10+ psi, you'll want to consider upgrading your internals.
