14 psi pully belt
Old Jun 5, 2007 | 03:33 AM
Curtball's Avatar
Default 14 psi pully belt
which size belt should I use for a custom 14 psi pully. and has anyone on here used the 14 psi pully yet, or are you guys all wimps.
Old Jun 5, 2007 | 07:25 AM
06SuperWhite_SoCal_tC's Avatar
If you contact NST when you order your custom pulley, which would be a no-brainer to order from them, they should be able to tell you what belt size you will need.
Or IceNine "Carl" should be able to tell you.
Old Jun 5, 2007 | 07:34 AM
ExEr101's Avatar
Cant wait to see this!
Old Jun 5, 2007 | 01:16 PM
jjos1's Avatar
Hey who you calling a wimp I think the best thing to do for that much boost is a larger crank pulley.
Old Jun 5, 2007 | 01:48 PM
Simplyscion's Avatar
Team No Limitz
theres not enough clearance to make the crank pulley significantly larger...Mike from NST and I along with a few others that were running the blower a couple years back came to that conclusion
Old Jun 5, 2007 | 04:33 PM
jjos1's Avatar
Bummer I think have a pulley small enough to make 14 psi would have slipping issues I would deffinitly like to see the numbers it puts down though. I'm thinking about a 11 psi pulley but I'm not sure if the trd injectors will give enough fuel.
Old Jun 5, 2007 | 05:28 PM
AndrewGene's Avatar
You should talk to kytc (if he is still even on these boards). He had a small pulley and couldn't get the belt to quit slipping. It was putting down about 2-3 psi less than what it was supposed to because of the slippage. He had a gatorback belt. I suppose that would still be the best.
Old Jun 5, 2007 | 07:55 PM
Curtball's Avatar
yeah slippage might come into affect, I'm gonna see what happens. but I figured sense I am gonna go all out with the s/c project I might as well get the 14 pully and see what I can do. my only problem right now is finding the key to remove this stupid bolt off the 07 s/c
Old Jun 6, 2007 | 02:04 AM
ExEr101's Avatar
What other engine mods do you have? You going to do anything to the block or head? Anything over 300 hp on a stock block is crazy.
Old Jun 6, 2007 | 02:35 AM
jetlounge's Avatar
stop whining and post a pic of the bolt with the key pattern.
Old Jun 6, 2007 | 02:52 AM
jasonrs2's Avatar
1UP Crew
i think vitviper posted a pic of the 07 pulley bolt once. try searching for it. good luck with the project.
Old Jun 6, 2007 | 04:20 AM
Gates > Gatorback
Old Jun 6, 2007 | 04:22 AM
Anybody who buys a new s/c right now.. 05-06 or 07 is going to get the new pulley bolt. My tC had the new pulley bolt when they recently replaced my s/c.
Old Jun 6, 2007 | 05:47 AM
Curtball's Avatar
yeah that bolt sux, and yeah try using that search button to find the picture of the bolt
CrowJenkins
Oct 9, 2015 10:47 PM
olyellr
Sep 28, 2015 10:32 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
Ksn
Sep 21, 2015 06:21 PM
