238whp with the TRD S/C and Stock Boost? *DYNO Inside!*
Josh i'm not slamming trd with my comments; we're running the stock sc and are happy so far with what it offers as such. My "point" was that it would be nice to see TRD taking the lead on some of this r&d, coming up with mods that will work with this unit; while letting us owners know why other mods won't work or be "allowed". In the old days, when manu's said something couldn't be done, it was left to the dealers, garage owners, or even rodders to figure it out first... but then you saw their results on the showroom floor. So my hope is that TRD sees that there is real need and interest out here, and helps take these cars to the next level. I never thought this unit was incapable ( in fact i think most of us would agree it has some solid, reliable, potential to be had ); i just think that the supplier could handle the marketing/development a bit better. There has to be intakes, exhaust, bpv's, etc that will work wonders with this unit; so if they don't want the aftermarket ones attached, then by all means come out with add-ons of their own that will work for us. At least give us owners the options instead of "no.. no.. no.." Sorry for the rambling, just wanted to toss my .02 out there... after all, if this car can be fun with near 200 hp at the wheels, i can imagine the smile you guys have with 220,230, even more...
And a tip of the hat to the individuals who are taking this unit on and showing us some nice options...
TRD add-ons would be a sweet thing, though.
^^ understood, and agreed. It's just when you get a postcard in the mail from Toyota to modify your TC, and all they can show is the sc, the axle back, and strut bar.... there just seems to be something missing.
well i guess for the next couple years we'll have fun with what we have..... then when warranty isn't a concern for us, let the games begin...
With all that said you also have to keep in mind where TRD is located. The C.A.R.B. & emissions laws in California are just outrageous. In order for these part to stay under warranty they have to be legal to put on the car. It took them forever just to get the ting to pass the way it is right now. TRD has offered part for some of their other cars that were "off road use only" and could effect your factory warranty. I know they offered headers for the Celica that carried no warranty and a Kazuma race exhaust that also had do warranty and we sold a ton of them. The reason they were available is because they were TRD Japan parts.
PghtC you're right to a point when you said there isn't a big enough market for them to offer parts. Trust me TRD has vision well beyond what most of us have here. But the point remains that if it isn't safe to put on the car and have it start every single day they aren't going to do it. To be honest the S/C's aren't exactly flying off the shelf not to mention the redesign that is going on so it will fit the 07 tC's. I think they just have their hands full right now.
If you're already running the max boost you want to run and you don't have any knock at full timing, then you should see minimal gains. Water/meth injection is really meant to take a car thats at the limit of safe operation in regard to knock and raise that limit. Either higher boost, more timing advance, or both.
Actually the test cars that the guys at TRD were driving didn't have any problems. Actually they're still driving them and they haven't have any issues as of yet. If I remember correctly they're had them for over a year now.
I can somewhat agree with you about the tightening the bolts down after the S/C is in place. I'm thinking that the techs aren't following the instructions all the way through.
This power was gained without knock, just a little tune tweak, adding octane to the mix, and getting the a/f's in check... and dont forget that cooling the intake charge helps power...
Originally Posted by Simplyscion
so what were the A/F ratios of the before run...and what kind of timing and A/F ratio did you end up running after you cooled it.
As you can see the a/f's for the TRD tune were sub 10 in some spots.
Originally Posted by IchijinMikomi
Are you suggesting that the TRD reflash knocks?
I don't think that's what he was getting at. I think he was just stating that water/meth injection are for cars with high boost and it's used to reduce/prevent knock. However in your case or the S/C case it builds a little power.
In the over all scheme of thing 20 hp is not alot. When you figure that you will need all the same part they had to make it. The boost cooler itself did not create 20hp. The combination of the header, exhaust, e-manage, and the boost cooler working in conjunction with one another created a total of 46hp. If you put the boost cooler on a straight stock set up with no engine management or that the reflash will more that likely produce less of a gain.
If the techs followed the instructions to the T then they shouldn't have a problem. So far it doesn't seem to be a wide spread problem.
one must be careful however...just like Nitrous, you dont just bolt this on and start spraying like crazy.
It can damage the engine if not used properly.
maybe the next FATF movie will be all about getting meth in their car instead of NAWS.
NAWS lmao
