2az internals
I realy want to know If the tc's internals are realy forged and have piston coolers. And what is different from the tc's 2az and the camry's 2az?
Re: 2az internals
yeah thats what i wanted to know! thanks. cause ive heard that they do.
Turbo is correct, crappy cast pistons, horrid toothpick rods... Not to impressive.
camry and tc 2az are the same. I think the previa 2az is the same as well but with a 4wd auto tranny. would make an interesting swap for a tc.......
I think you mean the RAV4, we are looking at a swap to AWD in a year or two;)
The stock rods and pistons have held up well on the tC version of the 2AZ while putting down some very respecable numbers. If you are building a car to actually drive the stock parts are fine for any reasonable amount of power. If you are more concerned with big dyno numbers but not a real car to drive around daily in then you will want at least pistons, the rods can take quite a bit of abuse as they are but if changing the pistons, may as well do the rods at the same time. Rick Rick |
The previa also have awd
I thought the rods were semi forged, the crank was forged and the pistons were cast with small ring lands for emissions (similar to the new Ford Mustang GT pistons and probably all newer modle cars).
If it was a manual tranny I would buy it right this very minute but it's an auto, bummer. Funny thing is I am moving approx 40 miles from there there the end of July, I will see if they can find a manual tranny one to bring in.
FYI, earlier previa AWDs sold in the US had a different engine and probably different transmission than this one shown. Uncharted territory here as well, no idea how much power the transmissions can handle, differential would be needed as well and questions about it's durability woul be uncharted territory as well. Along the uncharted territory line, this could end up being an insanely difficult conversion, at the very least it will be very time consuming and pretty costly even if DIY but sure would be fun, why we are going to look more into it in the future. Anybody have the time to dig around to see what has been done to the AWD "Previa" in Japan yet, even available in a manual tranny? I do not read Japanese so not much I can do but if somebody here does, that would be cool to have an interpreter! Rick |
The 05 camry 2az is NOT the same as the tC 2az. I dont have all the details, but I know that the bearing/cap assembly is different from what some of the shops have gone through trying to get parts for it. I dont know what else they changed.
As far as internals, Rick is correct. Take a look at the numbers a lot of people are putting down with stock blocks.
The only reason I would see for a change is knowing alot of the tC's will be boosted but that is an area that Toyota normally overbuilds most all their engines in. If you split the crancase on all the modern Toyotas I have seen, massively supported crankshafts are the rule.
The rod caps and bearings may be different(that would most likely mean the rods as well) The pistons are the only real weak link for any concern for longivity but the more critical factor is how you keep it tuned and how you drive it, again for any reasonable power level. At 10PSI a boosted tC 2AZ that is finely tuned, maintained and not redlined every time you shift should last for quite some time and a used engine is cheap if you break it:) Rick |
I agree Rick. If I remember correctly the bearings and rods were the area they were finding differences in.
I think ZPI bought Solara parts (another one with 2AZ) and they didn't fit.
Yep, there ended up being a parts site (cant remember it off hand) that actually listed the tC parts, but I am not sure if anyone has tried them yet. I seem to remember that ZPI did though
I guess if I was interested enough I could look in my Camry and tC Microfische files and compare parts numbers:)
Rick |
Yeah, Rick please do look up the parts no. and description of the bearings, rods and other internals to see if they are reciprocal items. I have a 2004 2AZ Camry and need to boost it up :nails: :nails:
I need to know if I could use tC parts when I up the booost :P :P |
