3" Exhaust = Power Loss and Lightened Flywheel = Waste
i've got my fidanza waiting to install with my comp stage 4 clutch... pretty excited about it, but yeah, im also curious about the steel vs aluminum... i heard the steel was slightly more likely to crack, is that correct?
Originally Posted by 20tCDude05
Originally Posted by Sleep3r
did you order a aftermarket clutch with your flywheel?? i dont think its a waste you just have to adjust to the different launch.........that OEM flywheel weighs a TON! I plan on getting a lighten flywheel later down the road.....
if you want to drag race the car then keep the 3" exhaust. you wil only lose a slight bit of low end torque. also keep the flywheel stock. a lightweight unit will rev faster, but your rpm will also drop alot faster between shifts. think of someone reving a sport bike.
Does the 3" exhaust reduce little low end torque and increases top end?
You got a lightned flywheel Brett?
Re: 3" Exhaust = Power Loss and Lightened Flywheel = Wa
I'm getting Dezod's S1 kit and I was searching on the 3" exhausts and saw that some people said that you can lose power due to less backpressure, is that true? Because I ordered ZPI's 3" Header-Back Exhaust System and I'm thinking about cancelling the order if that's the case.
And also, I ordered the Fidanza Lightweight Flywheel and I was reading on how it messes up your launch a lot and makes your engine unbalanced. Again, if that's the case, I might cancel my order. But, I do like the sound of better acceleration and less throttle delay.
So, I'm confused between the two issues. Can anyone help me out here?
"Lightweight flywheel messing up your launch and makes your engine unbalanced"......That comes out of the mouths of people who can't drive.
you should not be driving that car.
so, does your dad just directly pay for all your parts/install labor....or does he just give u the money and let you hand it to the mechanic??? :D
noobs....
