is 3" exhuast piping on s/c tc good or bad idea?
^^yeah but it's only blown to a certain extent...2.25 is probably the optimal size for a s/c...even with a few other mods. Now, if you get fully built internals...and push near 300whp...then 3" wouldn't be a bad idea
As ^^^ said ... it is not necessarily a bad idea if you plan on pushing bigger numbers but at this point you are wasting your money. While the Supercharger does give you the "blown" status, you really aren't blowing enough to need 3 inches. I would say that 2.5" would be sufficient for now and later.
Alot of the supercharged Cobalt SS guys up here around me run 3 inch header backs. They are making some good numbers. Now they run alot more boost then the TRD s/c so I might just say 2.5.
Originally Posted by TheQuietThings
Originally Posted by kikcaffine
Bad idea. you need back pressure still.
but this car is blown!
open that baby up!
I was thinking of doing a electric exhaust cut out on my setup, but I wanted to do either a rpm or boost activated switch. A large diameter exhaust would help out in the upper rpm range I would think, on the low end you would loose torque though.
For just a normal (the way scion set it up) S/C tC I would go no bigger than 2.5". Not only will you loose to much back pressure going bigger, but you will also loose exhaust velocity. You will loose on both top and bottom end.
Now if you are fully built top/bottom with high boost and putting out OVER 300hp you could see a gain over 2.5". Otherwise not worth it.
If your turboed.....go 3 inch all the way....if not 2.5 or under.......
I had 2.5 header back on intake header exhaust...made decent power.. hanging with mustang gts from a roll... turboed...im running 3 inch test pipe off the downpipe and my power changed alot from when i was running 2.5
They also reach full boost a lot lower in the RPM than the TRD does. I still feel 2.5" for the TRD supercharger is all that most people will ever need. If they decide to up the boost over 12psi it might help.
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
