5-bolt discharge turbo
Hey everyone i have the turbonetics kit which uses a 5 bolt discharge turbo , i want to have the turbo replaced its blown. Most places online sell 4 bolt turbos does anyone know of a good place online that has 5 bolt turbos ?
http://cgi.ebay.com/ebaymotors/AiRes...mZ160295319598
just woundering if thats a good deal , thanks again guys
Buy a turbo from an authorised dealer, which you will NOT find on ebay.
this way you have a chance at a warranty(as long as you install it correctly)
invest in a little more now, it could save you in the end.
Regards-
Todd
Regards-
Todd
Originally Posted by ValenciaS
hey if i have the original turbonetics turbo can i just by a 4 bolt and use the 5 bolt housing from the original one
it depends if that housing will fit the turbo hat you bought, or you can just cut your downpipe and weld a 4 bolt flange so it will fit your turbo discharge, its much easier
hey tcengel im just going to go with the turbo you have since you have the same setup as me , Garrett T3T04E 50 Trim w/.63 AR , ill take your word for it . Also how long did it take to ship since you added the 5 bolt , just woundering ?http://cheapturbo.stores.yahoo.net/gat350trw63a.html
You don't need a reducer. You need a 2" 90 degree elbow. This one:
http://www.treadstoneperformance.com...+Degree+Elbows
oh ok thanks , so all the turbonetics pipes will connect with no problem
let me see if i undestand this , the original turbonetics turbo has the wastegate runing to the bottom of that turbo , so this new one i have to run the wastegate to the throttle body that is where the blow off valve from the turbonetics kit is going with the T fitting, also if you dont mind would you happen to have a picture of this since you are running the same setup ?
You will need to get a silicone 90degree elbow or some sort of aluminum 90 degree bend welded onto the end of the comp housing to line back up to the intercooler pipes. We've helped do PLENTY of drop in upgrades to that kit.
