5 bolt turbo manifold
so im getting this turbo with the kit i bought>t3 to4e 57 trim..5bolt
what manifolds will work with this turbo...i was looking at doing a megan
the 4 or 5 bolt has to do with the turbine housing= dowpipe flange
the turbine inlet is usually always 4 bolt = t25, t3, t4 etc.
Most of the manufactuers of manifolds always offer a T3 flanged manifold.
Regards-
Todd
Regards-
Todd
^ You could do that, with the Megan Manifold and Downpipe you have to reweld the waste gate return line on the down pipe because it does not line up corrcetly, so you would have to have it welded any ways.
Honestly you can probably get one made for a decent price at an exhaust shop. Or get the megan one re-made. You could cut the wg return because the megan has a wg flange on it. It is purely up to you
Personally I would buy a new turbine housing and go external wg. That would be the cheapest routt
the turbo kit i have coming comes with a treadstone mani...i just don't really want to cut my radiator fan an inch off each blade...would i be better doing that tho?
You more pressing matter is your dp atm. You can take the wg actuator off and replace the turbine housing with a 4 bolt. That would probably be cheapest option.
The downpipe is the tube that comes off the exhaust side of the turbo. Shoot todd an email about turbine housings he can get you set up with one. I've never priced one
and the dp is a 5bolt design, topeka i would recommend u just either cut into the fan or get a slim line fan.... i wouldnt wanna pay to get stuff welded up would you?
and getting a new exhaust housing would cost big bucks too
i no a few professional welders so thats no big deal...thinking about doing the slimline tho...i also had heard tho that the megan gives better performance than the log so thats another reason i was looking at it
