6 Check engine lights codes!
Old Jan 8, 2009 | 02:45 AM
m6ar2cel6oTC's Avatar
lol miami driving what can i say. wel not cruise always that speed i mean when i was crusing that day 95 going to the track lol. we were in a rush. plus no traffic. but trust me i dont go that fast always it really starts at around 90 at 4000 rpms i think it is.
Old Jan 8, 2009 | 04:22 AM
Luiggi_OlympicMotorSports's Avatar
Originally Posted by m6ar2cel6oTC
yuh that happens to me at like around 4-4500 rpm cruising in 5th gear. but thats the rich code now the misfiring i have no clue.
Your Maf Scaling is off at crusing speed and it will linger between the MAP Clamp and the NA Clamp. I seen alot of people do that with their maps. Thats why I like street tuning b/c I rescaled all areas of the map. I like doing 1/4 TPS and slowly go to 100TPS so i can get a clean smooth transition from boost and just vacuum.
Old Jan 8, 2009 | 10:20 AM
crush02342002's Avatar
i never thought of that....rescaleing the maps on the fic for smoother transitions should work as well too huh?
btw with meth do you still need to retard a little timing? and what process do you guys do to tune with meth?
Old Jan 8, 2009 | 11:36 AM
Luiggi I will be contacting you after I get a dezod black box. So I can tune partial throttle also. Where on the airflow map show cruising speeds
Old Jan 8, 2009 | 11:59 AM
TCpete's Avatar
marcelo get rid of that dam emanage already man go with the fic! ..and ur tune is fubar bro... was it pablo who did that map for you?
Old Jan 8, 2009 | 12:19 PM
Yup u have just been messing with it since it was doodoo. I would get the aem fic but I would have to get the harness that's alot of money!!!!
Hey Luiggi you going on Friday to the track!???!??!
Old Jan 9, 2009 | 02:53 AM
highvoltage1's Avatar
Splice it. 4get the harness. save soem cash. GreddyTC did a write-up it looks pretty simple. Or if you dotn want too. go to Jacksonville and have him do it. Im sure pete can hook you up as well. Oh and Welcome back Pete.
Old Jan 9, 2009 | 04:18 AM
pete has a harness. i mean i can get someone to do it but i dont really want tocut the wires just incase
Old Jan 9, 2009 | 04:31 AM
Yea i wouldnt want to either but its an option. But check the classifieds i swear i saw and fic and harness for sale for like 600 or something.
Old Jan 9, 2009 | 04:45 AM
SoFloTC's Avatar
Tune with Luiggi ASAP how many times we gotta say it haha.. he works magicccc
Old Jan 9, 2009 | 11:51 AM
B_Real45's Avatar
Damn Marcelo.
It definitely seems like partial throttle tuning (not necessarily partial throttle boost) is way off. And yes, too much fuel can cause misfires - but too much fuel can also lead you to score your cylinder walls.. its called fuel wash.
Get this resolved ASAP.
Old Jan 9, 2009 | 03:39 PM
hey soflo have you dynoed your car yet? cause since i have the same turbo we would have the same amount of power more or les if luiggi tunes me. i'm curious. and are you going to the track tonight?
Old Jan 9, 2009 | 04:15 PM
I was going to try and make it out there but I think we are going to Tower Shops. Im going to the track next week with my car for the first time in a year.
Yes, You must rescale the 02 maps to keep it in open loop and then tamper with the MAF scaling between clamp and NA. You must retard timing even with meth on a high comperesion car regardless if you run pure 100 meth. Even though the meth does burn slower and cooler causing the comperesion to lower its still a NA stock comperesion motor with boost. You dont retard as much as you would with no meth but 1-2 degress more then Pump Gas. Must tuners add boost to take advantage of the meth. I like to add time to get better response and flow through the heads, plus the OEM head gasket and studs doesnt like much over 12psi.
Regards
Luiggi F.
Old Jan 9, 2009 | 04:17 PM
SoFloTC's Avatar
im in the process of a manual swap.. and idk if wed have the same numbers lol.. i got a built block and am on 15 lbs right now.. he said im like 380 area, u got a .63 back and .70 front on ur 60-1?
Old Jan 9, 2009 | 04:37 PM
Your actually on 16lbs (15.8lb) but sure 15lbs is close lol. You should be around 350-370whp... You should come to the dyno with us next week. Im fine tuning Mike's car maybe you should jump on for a quick pull if the tranny permits.
Old Jan 9, 2009 | 08:51 PM
whatever all i know is my tune sucks lol
Old Jan 9, 2009 | 08:57 PM
i have .70 compressor trim 58 and .48 back housing trim 72
master power 60-1
Old Jan 10, 2009 | 01:19 AM
tonybg1985's Avatar
Oh man I'd freak if that happend to me lol
Old Jan 10, 2009 | 05:30 AM
LOL dont worry I'll fix it for you. Also you should be around similiar power as Chad b/c of your set-up and meth.
Old Jan 10, 2009 | 05:38 AM
Hey Luiggi were are you located. I shoudl be tranferring to FL this summer and will be gettign a turbo and will need a tune.
