AEM F/IC hiccups under boost
Old May 22, 2008 | 05:13 PM
jjos1's Avatar
Does the injector pulse have any direct effect on how much fuel is added ?
I have not had any luck with my base map on my fi/c either. Any time I pull fuel it goes back to rich right away. I am pulling -32 fuel at idle with trd injectors and still have a cruising a/f of 12:1 no check engine lights or anything.
Old May 22, 2008 | 05:30 PM
paul_dezod's Avatar
Scionetics
KAD
The calculation to pull fuel to close to 14.7:1 AFR on the FIC is simple.
So if we changed from say 310cc to 660cc injectors then 310/660-1 = - 53 or - 53%.
Old May 22, 2008 | 05:31 PM
paul_dezod's Avatar
Scionetics
KAD
Pulse width is the amount of time that the injector is open flowing fuel.
Old May 22, 2008 | 05:47 PM
enjoithis's Avatar
jjos1 - have you tried my map? I idle and cruise perfectly 14.7 - im running 550cc's
Paul - have you looked at my maps?
Old May 22, 2008 | 05:49 PM
paul_dezod's Avatar
Scionetics
KAD
Bout to today.
Old May 22, 2008 | 09:09 PM
jjos1's Avatar
I did try it, it does cruise and idle good, but when I get hit the gas it leans of the chart. I rescaled it my injectors.
Old May 22, 2008 | 09:29 PM
enjoithis's Avatar
I found out that you can change the scale on the maps, i think when you convert to the new version the scale data is restore to defaults, leaving the map in the wrong place! Ill send you another map soon, mine is also too lean but ill be adjusting it. Looks like i need a fuel pump though, leans out @ 5500rpms even when injector pulse is 99.2 (max)
Old May 24, 2008 | 03:32 PM
RusWolf's Avatar
Are yoiu getting wahlbro 255 ?
how easy is to install ?
Old May 27, 2008 | 03:08 PM
enjoithis's Avatar
i might do that, im going to play with tuning a little more since alot of people say they have no trouble with 550s on stock pump, some people even running 11psi on stock pump and getting the right AFR's.
I didnt realize how much the O2 sensor map actualy affected the AFR - i might be playing with that this week.
Old May 27, 2008 | 03:17 PM
Secret_Services_Auto's Avatar
We had a similar problem with "hicups" on the 08 tC we recently finished on FIC. I beleive it has something to do with the closed loop mode on the factory ecu that just cannot be altered with a piggy back. One more reason I love full standalone.
-Evan
Old May 27, 2008 | 03:42 PM
enjoithis's Avatar
great... AEM suggested putting a 2.2k ohm resistor between some crank sensors, ill have to look to see which wires it was again.
Old May 27, 2008 | 04:10 PM
08superwhite's Avatar
is this the first '08 with this problem. i'm looking to get my f/ic tuned this weekend and am wondering if I am looking at similar problems. i'm gonna be running 700cc injectors
Old May 27, 2008 | 04:49 PM
jjos1's Avatar
a Hydra standalone is looking better and better every day
Old May 27, 2008 | 06:27 PM
B_Real45's Avatar
Someone tell me what the difference between they Hydra EMS and the AEM EMS??
They Hydra bandwagon is strong on this board.. I just want to know why.
Old May 27, 2008 | 07:09 PM
enjoithis's Avatar
are you running a fuel pump? keep us posted on how your tune goes
Old May 27, 2008 | 07:12 PM
no fuel pump. we are still looking for a third person to go in on the tune with us.
Old May 27, 2008 | 07:15 PM
enjoithis's Avatar
Originally Posted by AEM Admin
We heard from a customer with a turbocharged 2004 xB automatic who had misfiring problems, but that car didn't throw any error codes. Adding a 2.2k ohm resistor between the Cam1 MAGI+ and Cam1 MAGI- channels solved their problem. Please let us know if this helps your car also, we may need to update our wiring instructions.
I'll try this soon as it stops raining and i get a 2.2k ohm resistor. Still this wont fix y lack of fuel problem.
Old May 27, 2008 | 09:23 PM
jjos1's Avatar
Try changing the injector pulse to what the dezod base map was set at and see if that changes the a/f at all. It seems strange that 440 are big enough for a Greddy kit at 8.5 psi and you have 550 that are maxed out at 8.5 psi.
Old May 28, 2008 | 01:18 AM
paul_dezod's Avatar
Scionetics
KAD
It's very easy to max out injectors depending on where the MAF voltage clamp is enabled. Too early and they max out real quick.......
Old May 28, 2008 | 03:49 AM
enjoithis's Avatar
Paul - you've seen my map, is mine off by alot? I might look into changing that! So far ive only been playing with the fuel map
