AEM F/IC MAF Clamp
What was voltage on your XB before turbo?
This is the info that you need! Also what are your fuel trims?
Let me give you this example! Yesterday i tuned a car using a OEM air box. I changed maf to percent and set all zero's. I went into aem fic settings and put max voltage clamp to 4.40.
This was a 07+ I tuned the car and i was amazed at how smooth it was. Idle stayed pretty much between 14.6-14.8 I was able to tune the afr to a complete flat line during data logs.
I'm 100% convinced that fuel trims contribute to the P0101 code. IMO, the ECU assumes stock injector size and expects a corresponding volume of air to acheive a given AFR. If the MAF reads more air than the ECU expects based on fuel trim and a host of other variables, "Maf out of range" results.
vi3tb0i09
Sep 23, 2015 08:32 PM
