AEM MAP Sensor Placement
To those running AEM EMS, where do you have your MAP sensor placed? Apparently my placement is not good (too close to head on runner for cylinder 1) which is causing my oscillation in the signal under full boost. Now just debating the best location to put it. Could I just run it off the throttle body vac line? Would the VSV valve cause an issue with putting it on that line?
Anyone know what size the hose for the brake booster is? Im going to pick up some fittings to move the MAP sensor to that line here in a bit, but I dont have my car with me to check.
Moved my map sensor to brake booster, problem fixed
boost reading under full boost is now perfectly stable, and hell the car even runs much smoother in vac/light load. Wow I was an idiot for putting it where I did, guess it was just convenient at the time.
