AFR problem after installing new exhaust
ok..so, my and justin just installed my Ptuning 3 inch turbo back exhaust, and its awesome sounds great and all that. and whenever im cruising or at idle, the AFRs are perfect. but as soon as i start hitting boost the AFRs go right to 15 and continue to climb to 17...this happened on 2 different base maps weve tried, idle is fine, but boost is lean...
were not sure what to do, is it the larger exhaust thats causing the problem or what? we disconnected my battery to see if that helps the computer reset the tune better.
also justin said that with the ptunin exhaust the AFR sensor is behind the secondary O2 sensor, thats just how the set up is, instead of the other way around like it would normally be...anyones help would be greatly appreciated!
thanks
thanks
yea ive heard that as well, not much i can do though, dont have the money for a pro tune right now, maybe if anyone has a basemap setup for a 3 inch exhaust? i duno. im def stayin outa boost for now tho
instead of buying the exhaust you should have used that money towards a tune man. stop hitting boost if your hitting 15's and up! unless you want to blow ____ up! on boosted cars changing the exhuast is a pretty nice difference so it might just be the exhuast that changed your tune afr's!!
yea, well, ____ happens. i didnt wana let the deal on the exhaust i got go. so i chose that instead. and the only reason i was hittin boost was to test the different tunes. i had to see if we had a base map that works for it. oh well, gota pony up some money somehow.
oh and if i had gotten the tune first, then when i bought the exhaust i would have had to retune anyway, so ill just stay outa boost. i can deal. but maybe if i can find a basemap set up for a 3inch exhaust that will work....or i gota find someone that can street tune for cheap, that will cut me a deal or somethin
lol yea sry guys i was at justins, always forget to switch names...anyways crush might be able to help me out, were gona see...and i have the old exhaust that was just on my car to sell. so im gona try and get rid of that. lol i wish i had stuff around the house to sell. but i got nothinnn
i had the ARK n2 which is 2.5inch, but it had the secondary cat welded on to it where it bolts to the S pipe, because it came from cali and the have the restrictions there...and it was killin the air flow...its a beautiful exhaust and retails for like 700 bucks i think... i got the ptuning for 700 shipped(turbo back with s pipe)
yea i got a retune when i went to the 3in exahaust. just to let you know i was running the stock exhaust and an 8.6 lb spring in the wastegate. with the new exhaust my car now hits 10 psi. so adding an exhasut def required a retune.
im gona have to try and take switch back to the other exhaust on my own, cuz justins gona be to busy in the next week to help me. that or i just gota stay outa boost. well see what happens.
if i finish that clutch in time im gonna hit up luiggi for a tune next wensday i gotta call and see whats up.... sry matt ive been going non stop between work and my turbo kit.. then ur exhaust last night and me fixing my oil fittings then after today worked 7-5 non stop we were so busy im hella tired and still gonna go hit up the car meet tonight at 11 and work 2morrow am
wow, so heres an awesome story, on the way back from saint pete with my friend brock today, were on the high way, and we pull off to get gas, and i start hearing a loud freaking noise, and when i gave it gas i wasnt boosting. so we get to the gas station, i pop the hood and boom!
my waste gate bolts had come loose and one of the came out, my waste gate was hanging off the manifold my a thread. i lost the one bolt, we sat there for an hour until we found someone with a wrench, then we went to auto zone and got a new bolt...the gasket was blown out, and im gona have to lock grip the bolts...
ALSO! somehow my splash guard on the front right wheel got shredded the ____, and got stuck in my rim. i had to rip that out, so now i have no splash gaurd covering the fright right end of my car. AWESOME!
lifes great.
lifes great.
