After 9 months......finally boosted UPDATED with dyno #'s
Old Jan 16, 2007 | 01:56 PM
deathbyc4's Avatar
Default After 9 months......finally boosted UPDATED with dyno #'s
01/19/07
My baby finally has turbo!
May '07
Dynoed the car, with some smoking from the turbo, 267-271whp at roughly 10-12 psi on a crappy tune (what the dyno said, dyno dynamics 4 bar map sensor). need to retune the car after i get the turbo fixed.
05/11/07
Had to ship the turbo back today to Sound Performance because of a oil leak on the exhaust side of the turbo. Not really sure what caused it but it's under warranty,
Old Jan 16, 2007 | 01:59 PM
sddykstr's Avatar
Congrats!
Old Jan 16, 2007 | 02:07 PM
318_tC's Avatar
nice. my fuel pressure is set at 45psi.
ur using a safc for ems? who tuned it? dyno numbers?
Old Jan 16, 2007 | 02:17 PM
deathbyc4's Avatar
i just cranked it last night, untuned currently., still checking for leaks. I was supposed to go yesterday to get it tuned but ran into problems over the weekend and delayed my install. so no dyno numbers. i have pretty much the same setup you do, but i dropped the tank at the front to sneak the return line in there. I am unsing the Safc-II and the dezod black box (which is set to zero correction at the moment) for tuning.
Old Jan 16, 2007 | 02:19 PM
318_tC's Avatar
Gotchya. I wish you good luck, hope to see some killer #'a
Old Jan 16, 2007 | 03:03 PM
Prototype_xB's Avatar
seeing 14.8-15.2 AFR's here at idle on 550's
Old Jan 16, 2007 | 07:15 PM
deathbyc4's Avatar
I will see what I get tonight after checking everything over again for the 15 billionth time. I'm **** about things like that.
Old Jan 16, 2007 | 07:52 PM
DK01's Avatar
Default Re: After 9 months......
Originally Posted by deathbyc4
My baby finally has turbo! And now for some questions....
1) At current tune (provided by Sound Performance), I get a 14.3ish afr on the AEM at idle with 440cc injectors and fuel pressure of 40psi using Safc-II set at (if i remember correctly) -28% at 1000rpm. I plan on upping the fuel pressure to 45psi. Is that acceptable for an idle with turbo?
2) When I rev my engine what should I be looking for through the RPM range for an afr to make sure nothing is having a problem?
I'll post some pics when I get some decent camera shots.
1) 14.3 is normal at idle because your in closed loop. Your ECU will try to get the afr's at around 14.5 - 15.2 or so until you get your black box tuned.
2) Once you are tuned, you probably will see anywhere from 10.5-12.0 on your afr's. Otherwise, I highly suggest not to be boosting until you are tuned. If you need to do a little driving around.
Old Jan 17, 2007 | 12:50 AM
Joe_Dezod's Avatar
Congrats man! When you rev the engine your AF's will be sparatic, but anything from 13-15 is fine. The AVG will be 14.7 or so though. When there's no load and you're in VAC, you do not need to add any extra fuel than you would stock. As the turbo spools and PSI and CFM rise, that's when your AFR's should increase accordingly.
Old Jan 17, 2007 | 01:21 AM
deathbyc4's Avatar
Well, I'm still not able to run yet. I have a leaky donut gasket which the inner pipe that the donut slides onto is slightly short, but i think i can find a different gasket to fix it from leaking ( im not happy with the way they made their downpipe where it mounts to the s-pipe). I had my battery off overnight in case of fuel leaks and the car took about 10-15 min to start up, rough idle of course then it went to 14.0-14.3. Not yet the prettiest idle; i had to turn it off because of the donut gasket. So far no major leaks. I do fear some clearance issues once it hits the road but we'll see what happens.
Old Jan 17, 2007 | 01:24 AM
Joe_Dezod's Avatar
Well either way man let us know how it goes. PM me if you have questions on anything.
Old Jan 17, 2007 | 01:30 AM
deathbyc4's Avatar
Much appreciated!
Old Jan 17, 2007 | 12:04 PM
deathbyc4's Avatar
Stupid donut gasket. I need a 2.5" ID Type F gasket and I don't know if I can get one with a larger OD than the stock tC one. I have to go find one today. It's always the little stuff that drives me nuts.
Old Jan 17, 2007 | 05:29 PM
deathbyc4's Avatar
Yep, I found one. Had to drive all over town to get it. hopefully it will fix the leak. It's a F7466 donut gasket from Car Quest.
Old Jan 18, 2007 | 02:24 PM
Whocares05050's Avatar
post them pics buddy! lol.
Old Jan 18, 2007 | 03:29 PM
deathbyc4's Avatar
I'll take some tonight, Didn't get a chance yesterday.
Old Jan 19, 2007 | 01:29 PM
deathbyc4's Avatar
all i had was my phone at the time, i'll get some higher res pics soon.[/url]
Old Jan 20, 2007 | 03:20 AM
deathbyc4's Avatar
added pics at the top.
Old Jan 20, 2007 | 01:58 PM
rhythmnsmoke's Avatar
Music City Scions
Trying to go sleeperish with the black fmic huh....
Old Jan 20, 2007 | 06:23 PM
abe_mitchell's Avatar
nice setup
