Air Fuel Ratio? Install Injectors or not?
Old Sep 28, 2007 | 09:48 PM
jay_jay_n's Avatar
Default Air Fuel Ratio? Install Injectors or not?
Well i've had a zpi stage 1 kit for a few months now, and i barely got my injectors, i had a few issues with oil leaks and boost leaks omg thats a pain fixing and redoing etc.. freaken stupid oil pan lol..
well my question is i barely got my PLX Wideband installed yesterday and turned it on, i have not dynoed this car because i haven't had time or money to do so, and its been running great it basically was a stage 1 minus injectors , i have a e-manage blue with no tune and a profec-e01 boost controller.
I turned it on and it idled around 14 and when i would go WOT it went around 20 daym i'm leaning like crazy, well my question is should i put the rc 550cc injectors in or not, what would exactly happen since i don't have a tune will it at least compensate enough?
The reason i ask this is because i have a 6-7 hour drive that i'm doing tonight, and i've been fixing the oil leaks and boost leaks, and freaken exhaust leaks and installing new parts and i didn't realize how lean i've been. I kno i can try to play with the maps with my profec-e01 but i wouldnt even know where to start on how to tune it.
suggestions and help would be appreciated, and i know i will get it tuned as soon as i get funds to do so.
also i just got the DEI CRYO2 Intercooler Cooling system, would the cooler air effect my a/f even more?
Old Sep 28, 2007 | 10:07 PM
jay_jay_n's Avatar
also anybody know if i can upload a map like lets say the basemap from dezods site for the emanage to my profec-e01 and then to the emanage? because i don't have the support tool.
Old Sep 28, 2007 | 11:40 PM
Mr_Meaty's Avatar
You would need the support tool.
If you had 440cc, I would say go for it, but iwth 550cc, I think your gonna need a tune to get it to run.
Old Sep 29, 2007 | 12:09 AM
jay_jay_n's Avatar
yeah I installed them n now I'm reading at10 in gonna street tune if not I'll change them back any body have an idea how much % i should do, first time tuning it lol
Old Sep 29, 2007 | 12:39 AM
josh4201's Avatar
WATCHING!!
Old Sep 29, 2007 | 03:50 AM
Mr_Meaty's Avatar
You just popped em in and your seeing 10afr at WOT? Or all the time? Cause I know my gauge does not read lower then 10 (then again, it does not read higher then 17!) so who knows how low it really is!
Old Sep 29, 2007 | 05:47 PM
etsnet's Avatar
I think I'd rather run rich then lean. 10afr can be 8afr on the AEM if it's 10 flat I can bet it's the same for yours. Running too lean like that will kill your motor fast. Don't risk it, get a tune asap.
Old Sep 29, 2007 | 06:56 PM
Mr_Meaty's Avatar
um...wouldn't 10 or 8 be running rich? so it would be safer then running 17 or 20 like he was, which would be lean?
Old Sep 29, 2007 | 07:43 PM
knight's Avatar
Correct you are ,Mr Meaty.
Old Sep 29, 2007 | 07:56 PM
etsnet's Avatar
Yes 10 or 8 is richer (stil not super safe) but safer then being that lean at WOT.
Old Oct 1, 2007 | 08:12 PM
jay_jay_n's Avatar
well thx for the help guys actually my wot would be around 14 from what i tested and i drove fine there, scarry but i made it back in one piece, i had installed the injectors and i was at 10 and the car ran like shiet so i had to change them back to the stocks, is this normal? it was boggy as hell and i did check the wiring etc..
well the great thing is had a dyno run at the show for free, but no tune just a pic and vid of the run i'm gonna get the stuff uploaded but i was suprised how well i did with no tune and injectors at 8psi 220.91 whp!!, but i was losing at least 15hp because of a exhaust leak somewhere that is loud as hell.
what u guys think?
Old Oct 1, 2007 | 08:29 PM
knight's Avatar
Are you running an open dump off your waste gate? I beleive it's bogging because at 8 psi you need more fuel than your stock injectors can put out. If you are not an experienced tuner you NEED to get it tuned or start looking for a new block. Running 14 at WOT is very bad.
Old Oct 1, 2007 | 08:32 PM
Angry_Celi_Guy's Avatar
i feel sorry for ur engine
Old Oct 1, 2007 | 09:10 PM
Mr_Meaty's Avatar
Well, you were bogging AFTER you put in the injectors, right? So your bogging cause you dumping to much fuel.
One of the tunes I got are from a car with smaller injectors, so my car reads in the 10s and it boggs down. My original tune does not bog down. It's the larger injectors on a stage 0 with no tune.
You just have to get tuned. There is no way around it, no other solution, just do it!
Old Oct 1, 2007 | 10:07 PM
jay_jay_n's Avatar
yeah definitely getting it tuned just trying to fine time to get it tuned, u gonna go to HIN Vegas? and finnally meet me Mr. Meaty?, well i hope i can get it tuned this week, only problem is scheduling time, i wish there was a good tuner in my area.
Old Oct 1, 2007 | 10:33 PM
malloynx's Avatar
dude, wtf are you talking about. a 10afr is retarted rich. even low 11's in rich for such little boost. it's like the blind leading the blind around here.
to the fella that is having problems. get yourself some 440's or so and run a return fuel setup. it's soo much easier to tune when you can adjust fuel pressure. i've seen people that are really good tune a motor on just fuel pressure alone (no engine management) that's if you really don't care about your timing.
Old Oct 1, 2007 | 10:57 PM
Mr_Meaty's Avatar
I think etsnet clarified in his follup up post that it's safer to run 10afr rich then it is to run 20afr lean.
But yeah, 440s would probably work. I was gonan run 440s when I could not find a tuner, but I did, andI got 650!
I'm gonna try and make it, but it may not be till later in the evening cause I have some place to be at 5:00
Old Oct 2, 2007 | 09:06 PM
etsnet's Avatar
x2
You ran 14afr at WOT and went on the dyno. Dude, you are gonna kill your motor. Try to stay out of boost until you can get a tune.
cessblood
Sep 15, 2015 06:50 AM
nightfox915
Apr 17, 2015 07:06 PM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
TheRedBox
15
Jul 9, 2006 04:08 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
