Alcohol/Methanol/Water Injection Q&A...
Originally Posted by olaHalo
^^ you should give that turbo away. itll do you no good and your just going to break it. but hey! theres a guy up the street that you can give it to. hell take care of it for ya
Originally Posted by UltimateCC
how laggy is your turbo?
I understand the importance of using water/meth inj. on supercharged setups (primarily because of the inefficiency and diffculty of putting an intercooler setup on), but is there a benefit on a turbo system to have a water/meth inj. system versus an intercooled system? Since I live in an area where it is hot, I am more concerned about cooling efficiency over power gains. Thanks.
turbos typically pick up and benefit even more from meth injeciton, you can increase boost more than on supercharger typically, you lower IAT tremendously, can increase timing and lean afrs out...the turbo buick guys were some of the first to start using meth injection on a larger scale...
With a turbo setup, after installing the snow performance stage 2 boost cooler, where will the water/meth solution inject? Is it safe to have the injection point after the MAF but before the turbo? Is the water/meth solution going to decrease the life of the turbo? Thanks!
Im running a zpi stage 0 and am interested in this as well, I plan on going with the Snow stage 1. Would the water/meth inject between the turbo and the throttle body? And if so, should it go closer to the turbo or closer to the throttle body? Thanks
sounds like some pretty interesting stuff i know a couple of the boosted guys running around here are running the water methanol injection. I am getting ready to order the stage 0 from zpi and i was wondering if i went with the stage 2 and then installed an intercooler down the road would it still be worth it ?
you want it 6-10 inches from TB...
-Chris
-Chris
I am more interested in cooling (even though the power gains are welcomed) aspect of the water/meth system. Are there are numbers related to "cooling" or temperature drops as a result of using the water/meth system? Thanks!
