ANTI FOULER-TURBO
Old Oct 23, 2006 | 08:53 PM
Byta27's Avatar
Default ANTI FOULER-TURBO
With my turbo kit i dont have a cat, but i do have the anti fouler mod is there a different antifouler out there i know there is a longer one i have the shorter one or somthing that u guys have used that is proven to take that cell off as i had the code read and it said it was the catlytic converter.
Old Oct 24, 2006 | 03:26 AM
Prototype_xB's Avatar
which antifouler do you have?
Old Oct 24, 2006 | 05:07 AM
Byta27's Avatar
its the one from www.racingsolution.com
Old Oct 24, 2006 | 05:10 AM
There is an antifouler DIY here on the boards. I've already assembled one for myself. It consists of buying two HELP! brand spark plug non-foulers. Boring 1 our with a 1/2" bit, then threading together, with bored foulder on bottom for secondary O2 sensor, then threading into the s-pipe. I'll search for the page i saw it on real quick....
Old Oct 24, 2006 | 05:11 AM
you bought this electronic one from racingsolution? --> http://www.racingsolution.com/showpa...on=DisplayPart
Old Oct 24, 2006 | 05:12 AM
Byta27's Avatar
thats exactly what i have now zero told me to get this one http://www.monstermotorworks.com/cgi...&ppinc=search2
Old Oct 24, 2006 | 05:20 AM
Byta27's Avatar
no i do not have the simulator i have the extender thing the 2 things that screw together to extend the o2 sensor out
Old Oct 24, 2006 | 05:31 AM
Here's the antifouler DIY. Its near the bottom of the write up. You'll see it:
https://www.scionlife.com/forums/vie...=56520&start=0
Old Oct 24, 2006 | 05:38 AM
Byta27's Avatar
yes i have the same one on there when i had headers it worked fine but with the turbo now it does not work and it is on the spipe i have the exact same antifouler i was just thining that maybe this one mught be better cause its longer http://www.monstermotorworks.com/cgi...&ppinc=search2
Old Oct 24, 2006 | 05:44 AM
and that didn't get rid of the cel?
Old Oct 24, 2006 | 05:45 AM
Give it a shot
Old Oct 24, 2006 | 07:47 AM
Byta27's Avatar
nope it did not work thats y i dont wanna waste 55 bucks on the longer one unless i know its going to work
Old Oct 24, 2006 | 07:55 AM
which turbo kit are you running?
Old Oct 24, 2006 | 07:59 AM
Byta27's Avatar
dezod
Old Oct 24, 2006 | 08:16 AM
Hmm. I would try adding 1 more spark plug non-fouler to the group and just see what happened.
Old Oct 24, 2006 | 08:54 PM
DK01's Avatar
What about just adding more of the HELP brand adaptors to make the one you have longer? Same concept basically.
Old Oct 24, 2006 | 09:03 PM
Old Oct 24, 2006 | 09:58 PM
DK01's Avatar
^^ beat me to the punch.
Old Oct 24, 2006 | 10:30 PM
Turbonetics has an O2 extention in their kit that is 3.5" long. I just took some measurements of the DIY HELP! Brand antifouler i have and if you add 1 more non fouler to the 2, the overall is 3.6"
Old Feb 13, 2007 | 10:52 PM
Crippie's Avatar
1UP Crew
Good thing i did a search before posting my question... I had the 2 antifouler set up with my headers before I went boost. My question is, since I have the emanage, should i still be using the antifouler setup? wouldnt that give the ecu a false reading when it comes to a/f ratios? <--- probably a newb question
