Anyone have boost gauge install pics!
Old 04-15-2006, 04:16 PM
TCTuNeR80's Avatar
Default Anyone have boost gauge install pics!
I am ready to hook up my boost gauge on my Turbonetics TC. But i want to research it first. Can anyone help me, I dont know exactly where all the wiring goes. does anyone have any pics to give me a reference. Thanks
TCTuNeR80 is offline
Old 04-15-2006, 04:24 PM
TCTuNeR80's Avatar
And then theres the Greddy Turbo Timer. This I am at a total loss. I dont think I even want to try to hook this up.
Old 04-15-2006, 05:04 PM
tikbhoy's Avatar
it is sometimes easier said than done. a manual will help. keyword would be vacuum.
install pics ? most of the thread in main page has install pics
here are some
* w/o gauge pod. temp
* heres mine with autometer gauge pod+trd
theres alot more people with different setup
tikbhoy is offline
Old 04-15-2006, 05:30 PM
TCTuNeR80's Avatar
I know how to hook up the vaccum line. its the wiring im not knowledged in
Old 04-15-2006, 05:46 PM
Nick06tC's Avatar
I just got in from doing mine like 20 minutes ago. I did 3 gauges but for the wiring. Its pretty simple. You will need a MINI fuse tap from autozone or where ever. the power line goes to that then tap into a fuse that comes on with the car. I did my dash lights. Then the negative wire you just need to ground to a bolt under the dash. I used the one that holds the break pedal (or was it clutch) in place.
If you have any SPECIFIC questions just ask.
Oh yeah I am local as well. We have a local car club for scions. Scionevolution.com check it out. We have a few local shows coming up if you are interested in hanging out sometime. We also get togethor most saturdays.
Nick
Nick06tC is offline
Old 04-15-2006, 06:04 PM
tikbhoy's Avatar
^ as said it look like this
* you wont be able to use the cover BUT if you dont Leave it in your glove compartment just in case.
* use the right fuse to it.
tikbhoy is offline
Old 04-15-2006, 07:40 PM
TCTuNeR80's Avatar
Hey thanx, that doesnt look too bad. I always do the work myself. and I always research everything first so i dont jump in there blind.
Old 04-15-2006, 07:42 PM
tikbhoy's Avatar
ONE TIP + unhook your + battery
if you do tap under the bolt off the pedals, ZIP TIE IT. you dont want that tangled on your feet when you need to STOP.
it doesnt look bad but they charge alot for it tho! it does make your life easier and is better than splicing any wires.
tikbhoy is offline
Old 04-15-2006, 08:54 PM
tikbhoy's Avatar
heres to give you more ideas, im pulling them off threads posted around SL
* there is also one more that relocated his climate control wheel and mounted a gauge right there.
tikbhoy is offline
Old 04-15-2006, 09:49 PM
Nick06tC's Avatar
I paid 8 bucks for the tap. Accidently got the bog one, then had to go buy the mini one. What a waste. Make sure its mini and you use the corisponding fuse.
Nick06tC is offline
Old 04-16-2006, 04:06 AM
ERIC-TC's Avatar
I did mine in the cubby hole below the center console. Got a 3-pillar gauge pod on order for more junk.
https://www.scionlife.com/gallery/?photo=21785
I used the wire that powered the cubby-hole light to "illuminate" the gagues. I tapped into the 12V acc plug for acc/on power to the oil pressure gague.
Routed the wire from inside the engine-bay through the side of the drivers side rubber grommet and wire-tied the wires, vac-line to the back of the cubby-hole.
Took me two days to do but it had to look perfect and all my connections where soldered and I drilled no holes.
ERIC-TC is offline
Old 04-21-2006, 08:35 PM
jay_jay_n's Avatar
where is this posted? i would want to kno how much it costs and more pics of it.. also how stable it is?
jay_jay_n is offline
Old 04-21-2006, 10:02 PM
HighlanderMac's Avatar
Tik, lol, that first one looks like a Black Marshmellow exploded in the car.. hahaha.. Sry, but I think it needs to be cleaned up a lil.. lol, Whos is that?
But oh well, here are some pics of my old setup.
HighlanderMac is offline
Old 04-21-2006, 10:06 PM
PghtC's Avatar
If you did not drill any holes, then how did you get them to be stable and not move around in there?
PghtC is offline
Old 04-22-2006, 03:52 PM
fishingexpert87's Avatar
hey highlander, is that plexiglass you used? how did you cut it, with a dremel?
fishingexpert87 is offline
Old 04-22-2006, 04:10 PM
Actually it is metal, I bought it from someone on here, I cant remember who. I will have to look it up.
Old 04-23-2006, 06:37 PM
the415_Dallas's Avatar
that has got to be the worst looking fiberglass work i have ever seen. not to mention the huge ____ing tach. what's wrong with the stock one. jesus christ, some people should NOT mod cars at all because all they do is ____ em up and make themselves look like a jackass. whoever owns that car can not tell me that they are happy with the outcome of that monstrosity. god they need to be shot!!!
the415_Dallas is offline
Old 04-23-2006, 08:28 PM
retrodrive's Avatar
Actually the rest of his car is great. One of my very favorite TCs on this board.
retrodrive is offline
Old 04-23-2006, 10:50 PM
legionscion's Avatar
who the hell want a big ___ Rpm tech
legionscion is offline
Old 04-23-2006, 11:00 PM
davedavetC's Avatar
keep it on topic, you want to talk about htat persons work, PM him (if you dont know who it is search).
davedavetC is offline
Quick Reply: Anyone have boost gauge install pics!
