anyone with pic's of oil catch can installed on tc?
Old Jan 20, 2007 | 09:30 PM
matt593tc's Avatar
Default anyone with pic's of oil catch can installed on tc?
If anyone has pictures of oil catch can installed on there tc's i'd like to see them. Thinking of getting one and if its worth it. How and where to mount it would be helpfull also pictures would be best.
Old Jan 20, 2007 | 09:44 PM
deathbyc4's Avatar
Oil catch can pic
Old Jan 20, 2007 | 09:49 PM
rrimportracer's Avatar
lol ^^^ nice got me
Old Jan 21, 2007 | 02:48 AM
soros151's Avatar
^^ me too
Old Jan 21, 2007 | 05:20 AM
matt593tc's Avatar
good one not what i was looking for
Old Jan 21, 2007 | 05:27 AM
search button works real good, you should use it sometime
Old Jan 21, 2007 | 05:35 AM
captainlaziness's Avatar
ScionDad's pic.
Old Jan 21, 2007 | 05:39 AM
Here's a couple more. Different location and style.
retrodrive's pics.
Old Jan 21, 2007 | 02:02 PM
matt593tc's Avatar
witch breather is used of the engine. the one in the back going to the intake manifold or the one off the side of of the engine going to the intake.
Old Jan 21, 2007 | 02:52 PM
i would use the one on the side that goes to the intake,
Old Jan 21, 2007 | 05:07 PM
yamaha16bw's Avatar
mine
Old Jan 21, 2007 | 05:10 PM
w3paint_xA_xB's Avatar
Originally Posted by yamaha16bw
mine
is that the Greedy oil tank? and would it run on the xB as well?
Old Jan 21, 2007 | 09:45 PM
soros151's Avatar
mine
what battery is that?
Old Jan 21, 2007 | 09:55 PM
yamaha16bw's Avatar
Its a greddy style. Not a real greddy....I wasnt going to pay 100 bucks for that. If you can make it fit it will work on any car.
The battery is a Odyssey PC680MJT
Old Jan 22, 2007 | 05:03 PM
ERIC-TC's Avatar
I took my valve-cover off and tested the ports... The port on the drivers side has a one-way valve on it so you don't leak vaccum into the intake manifold. So you are really not catching anything by hooking a catch-can to the right-side valve-cover port. The port connecting the intake manifold to the valve-cover -That's what you should be looking into if you want the catch-can to actually do something.
There has been some conflicting information on which side has the one-way on SL. My info came from my 06 tC valve-cover when I removed it a couple of weeks back. That's why you can remove the right-side valve-cover hose and you will not feel any suction at the actual valve-cover port (be sure to plug up the intake side of the hose you you will get an air-leak).
Old Jan 22, 2007 | 09:01 PM
scion2007tC's Avatar
Originally Posted by deathbyc4
Classic!
Old Jan 22, 2007 | 11:31 PM
yamaha16bw's Avatar
Thats good to know! I'm taking my valve cover off in a few days for powdercoat and I was going to check the same thing. I'll have to hook my oil tank up to the rear vent hose then.
Old Jan 23, 2007 | 04:51 AM
mattieg's Avatar
So where do you hook up the hose?
Old Jan 26, 2007 | 09:12 PM
matt593tc's Avatar
not to be confused but on my tc the one way is in the back. I know this cause i took the hose off the manifold and tryed to blow through it and i couldn't . Air dose go through the opposet way though. everyone says the one way is on the side so thats what i did to see. the one on the side air can pass both ways.. If anything I would prob run a catch can on both vents with a Y conector into a catch can then out to the intake side.
my06tc
Jun 25, 2015 12:18 AM
Wes_R
Regional - Canada
Feb 4, 2015 10:49 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
bBOXD
28
Dec 7, 2003 07:08 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
