Anyone running the Camry transmission?
Camry gear ratios:
First - 4.24:1
Second - 2.36:1
Third - 1.52:1
Fourth - 1.05:1
Fifth - 0.76:1
Final - 3.29:1
Scion tC gear ratios:
First - 3.54:1
Second - 2.05:1
Third - 1.33:1
Fourth - 0.97:1
Fifth - 0.78:1
Final - 4.24:1
just some facts for thought...
First - 4.24:1
Second - 2.36:1
Third - 1.52:1
Fourth - 1.05:1
Fifth - 0.76:1
Final - 3.29:1
First - 3.54:1
Second - 2.05:1
Third - 1.33:1
Fourth - 0.97:1
Fifth - 0.78:1
Final - 4.24:1
the more i look around it seems there are several different gear ratios they have used in the camry transmission
this is the gearing in the newer camry
3.538
2.045
1.333
0.972
0.731
Final Gear Ratio
3.944
basically looks the same with the exception of 5 gear.. hmm
so im guessing you would have to go with a older transmission to get the longer 1-4 gears
jsg93085 do you know what year you got those camry ratios from?
3.538
2.045
1.333
0.972
0.731
Final Gear Ratio
3.944
weird mine came from a 07
here is a mph break down of the ratios you posted these are at 6.5k rpms
camry
1. 34 mph
2. 61 mph
3. 95 mph
4. 137 mph
5. 190 mph (holy poop)
tC
1. 31 mph
2. 54 mph
3. 84 mph
4. 115 mph
5. 143 mph
idk to me the camry gears look better
camry
1. 34 mph
2. 61 mph
3. 95 mph
4. 137 mph
tC
1. 31 mph
2. 54 mph
3. 84 mph
4. 115 mph
5. 143 mph
do like rythm said greddy ultimate and there you go speed limiter and rev limiter increased done deal! and if your auto go manual point blank if not ask soflo how he has a built auto tranny and hes selling it to go to manual!!!
yeah that's not gonna happen on a stock valve train
Originally Posted by SoFloTC
im planning on raising my redline to 7 with just upgraded valves no springs or retainers.
camry
1. 34 mph
2. 61 mph
3. 95 mph
4. 137 mph
tC
1. 31 mph
2. 54 mph
3. 84 mph
4. 115 mph
5. 143 mph
camry
1. 34 mph
2. 61 mph
3. 95 mph
4. 137 mph
tC
1. 31 mph
2. 54 mph
3. 84 mph
4. 115 mph
5. 143 mph
143mph? Must be without the speed cut. Then again, without the speed cut it's still higher than 143. You going to find yourself doing a LOT of work just for a couple of mph in the gears that you could have achieved by simply adding a management solution that could raise rpms.
No you wouldn't. 6500rpm would get you pretty close to those mph, except for the top speed.
And PLEASE tell me where you going to be racing at 190mph IF it can even get up to that speed.
I can see it now. You swap in the Camry tranny and then brag how your tC can go 190mph top speed. That = Ricer.
You can go to 7 on a stock valve train. It's been done and it's not going to blow up on you like you might think. I'm going to raise mine to about 6700-6800.
and i already stated that you could do about 7k on the stock valve train no need to restate it like i was denying it lol
here is the tC's gear vs speed ratios if you where to increase the redline to 7k
1- 34 mph
2- 58 mph
3- 90 mph
4- 124 mph
5- 155 mph
quite a bit off from the camrys in most except for 1st
and here are the rpms in which you would need to increase it to in order to match the camrys mph in each gear
1- 7000
2- 7300
3- 7350
4- 7700
5- 8600
and obviously i wouldn't be racing up to 190mph however it would make a fantastic gas saving cruising gear on the highway.. you would be cruising at only 2250 driving 65mph instead of 3k like with the stock gears
and whats talk of all this extra work.. im gonna be taking the transmissions off anyways in order to put my flywheel and clutch in. so if the transmissions housings are the same there is no need to spend any extra money other then on the transmission it self which is fairly cheap.
1- 34 mph
2- 58 mph
3- 90 mph
4- 124 mph
5- 155 mph
1- 7000
2- 7300
3- 7350
4- 7700
5- 8600
Your numbers are off. I'm going by an actual tC that had increased redline above factory. If you left the redline stock and remove the speed limiter, the Mph is more around 147mph.
Here is the bottom line:
tC increased redline + speed limiter removed > tC with camry tranny installed.
On top of that you still going to have the speed limiter set at 127mph, camry tranny or no camry tranny. So, you STILL going to have to take that off via an external ECU/module.
Remember, we are limited to 127 via Electronic means, no gear.
But do it man, not saying it wouldn't be interesting to see what it will handle.
lol dude its like your not even reading my posts
they are 100% right if you where to take off the speed limiter, 5th gear would physicly top out at 143mph with the stock tire size ratio not 147. you could get to up over 147 if you had the wrong size wheels and tires though. 215/45/18 would bring you to 149mph but then your speedo would be off by about 4.1%
and obviously if you have a turboed tC your gonna already have some sorta ecu management thus you would probably already have the speed limiter removed.
the lengthen gears of the Camry is more suited for drag racing in a turboed tC. with the camry trans you only need 1 shift to reach 60 but in the tC you need 2 shifts. this will make for faster 1/4 mile times. not only that but if you had the Camry transmission and raised the redline to 7k you wouldn't have to shift out of 2nd until 66mph. i don't understand how you don't see the benefits in this
I wasn't talking stock tire size, my bad. Do you feel safe running stock tires at 140+...I know I don't.
90% of the turbo tC's have Emanage Blue. Does not remove the speed limiter. The other 10% have an F/IC, which also don't remove the speed limiter. So, I stand by what I said. There are only a handful that have standalones or the Emanage Ultimate (I am one of those few).
I stand by my prediction. Prove me wrong not with numbers, but actual performance when it gets in the car.
This has been discussed elsewhere as well (ystc.org). Swapping for a Camry 5spd is only going to net you higher MPG due to the longer gearing of the Camry transmission.
Anyone with F/I may not have any issues with the longer gearing, but on a stock motor, the tC will feel slower compared to a tC with its stock transmission.
Some have suggested swapping out specific gears from a Camry transmission (i.e. 5th and Final), but I don't recall anyone ever posting that they did so...
look just go for the camry swap and see how it goes. lets see if you say i should have gone with raising the rev limiter and speed cut lol or say F*** ultimate and get a swap lol!
point is you'll never find out anything unless someone did it and no one has so go for it. worse comes to worse keep your stock tranny incase you run into any problems and have to go back. Keep us updated!
