APEXI TURBO TIMER INSTALL
Can anybody please please help me with how to install this turbo timer on our car i looked at it and my mechnic did as well and this thing seems to be a nightmare. If this one is really as hard as it looks what would be the easiest one to get with the easiest install.
byta i think you should probably go with the greddy turbo timer, it looks sweet and every1 seems to love it, using my mind reading skills i can tell thats wut u originally wanted and ur friend nick told u to get it, so you should probably do that b4 you hurt yourself haahahahah
Well I have the Apex TT but its really easy to hook up so I dont know why your having trouble. It was along time ago when I installed mine so I forgot the colors of the wires but its very simple. PM Joedezod cause he uses the same TT.
Its only like 3 wires and your set....not a mightmare in any way
Just to make sure this is the TT your talking about right?
Originally Posted by ProshopXB
Originally Posted by yamaha16bw
O Proshop I think you gave me the wires for my TT could you post those again for this guy?
05 Scion tC- Wire colors
Wire: Wire color/ Polarity / Location
12volts: red or white/ + /ignition harness
Starter: black / + /ignition harness
2nd Starter: green / + /ignition harness
Ignition: blue / + /ignition harness
2nd Ignition: yellow / + /ignition harness
Accessory: gray / + /ignition harness
Keysense: black / - / ignition harness
Power Lock: green with blue stripe/ - / driver kick, 20 pin plug, pin 15
Power Unlock: purple with pink stripe (double pulse)/ - / driver kick, 20 pin plug, pin 14
Parking Lights: brown/ + /top of fuse box, 30 pin plug, pin 29
Parking Lights: brown / - /headlight switch
Reverse Light: pink / + / top of fuse box, 14 pin plug, pin 2
Door Trigger: orange (D), blue (P)/ - /top of fuse box
Dome Supervision: blue/ - /L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin: purple/ - /top of fuse box, 30 pin plug, pin 7
Trunk/Hatch Release: orange/ - /driver kick, gry 12 pin plug, pin 12
Tachometer: black / ac / data link conn. under dash, pin 9
Brake Wire: blue / + /brake pedal switch
Parking Brake: black/ - /parking brake switch
Horn Trigger: white / - /horn switch
Originally Posted by tc2nut4
no plug n play huh... can't believe with the number of F/I TCs runnin around no one has hopped on that gravy train lol
Copy and save
