View Poll Results: Does it look like i have a bad seal?
Voters: 10. You may not vote on this poll
Bad turbo seal? Please help
i talked a bit about this in another post but i wanted to give it its own thread, i was just wondering what else besides a blown seal could cause oil to be in the hot side of the turbo housing? maybe this is normal idk?
my story...
i bought a used turbo kit that has about 5-6k on it and there is oil all inside the compressor housing. there is quite a bit of oil also lining the hot side pipping all the way into the intercooler, the cold side however is clean, so apparently its not getting threw the intercooler. the owner says the car didn't smoke or anything however i found out he blew the oil return line and im not sure if that has anything to do with the oil in there. is that a possibility? or could it have actually caused a bad seal?also there wasn't much oil coming from the crank vent inlet so i doubt the oil is coming from there.
im just trying to figure out what to do about it.
here is a video
thats after a little bit of cleaning in the inlet
outlet coming from the turbo to the intercooler
bottom of that pipe where oil has collected, you can also see the pipe lined in oil sut. its like that all the way into the intercooler
this is what it looks like when i wipe my finger in the turbo or top of the piping.. pretty thick
my story...
here is a video
could deff be a blown seal, could have also been a drain problem which made the oil push passed the seal. Which a turbo is designed to do.
Id have it looked at, try to find some place local that you could just drop it off to save on shipping. They will be able to pull it apart and check all the seals/bushings
Originally Posted by 20tCDude05
I never had problems with it dude.
here is the video i posted in the other thread... does anyone know if this is normal spinning and shaft play for this turbo?
http://www.youtube.com/watch?v=U7Gl6v56opo
Originally Posted by unxpectederror
yeah problem is i don't know of any local places that repair turbos
ive looked around but haven't found anything.
but turbochargers.com has 30 years of rebuilding experience. They have done 2 of my buddies local, not a hitch with either of them.
yeah i searched for local places but to no avail.. if anything ill have to have it shipped out.
how much does a rebuild normally cost? i was quoted $250 does that sound right?
carid
Mar 30, 2015 07:08 AM
Kodokan_4
11
Dec 4, 2004 01:34 AM
