Balance Shaft Delete Kit - Pros/Cons - No Delete Kit Yet???
Old Jan 21, 2009 | 07:32 PM
johnhawkins's Avatar
Default Balance Shaft Delete Kit - Pros/Cons - No Delete Kit Yet???
I used to own a Mazda 3 and had removed the Balance Shaft. Bought the kit for like 20 bucks. Just a simple screw and a plug bassically. It removed about 13lbs i believe and also helped reduce parasctic drag on the engine. Was a noticable gain and easy to install.
It DID increase engine vibrations. Can we do this on the 2azfe???
Old Jan 21, 2009 | 07:38 PM
StreetStarsTc's Avatar
i heard of someone doing this. not sure if it was documented on here tho.
i'd like to know as well.
Old Jan 21, 2009 | 07:54 PM
nodsetse's Avatar
Yes, there's a delete kit for the tC...seem to recall Dezod makes/sells it, but could be mistaken. There's definitely a thread where it was announced, so try a search.
Old Jan 21, 2009 | 08:08 PM
NotAStockScion's Avatar
no kit
remove balance shafts, plug hole, done
Old Jan 21, 2009 | 08:50 PM
rhythmnsmoke's Avatar
Music City Scions
Where is a DIY on it?
Old Jan 21, 2009 | 08:56 PM
SW_08's Avatar
x2
Old Jan 21, 2009 | 09:07 PM
nodsetse's Avatar
Originally Posted by NotAStockScion
no kit
What do you mean "no kit"? You don't have to have a kit to remove them, but a kit does in fact exist.
EDIT: It was ZPI that made a kit for the tC. IIRC, it included a windage tray.
Old Jan 21, 2009 | 09:28 PM
B_Real45's Avatar
You don't need a kit. Just some JB weld for the holes.
Old Jan 21, 2009 | 09:29 PM
I wish there was.....Dezod.....pretty please....I'm a Buffalonian!
Old Jan 21, 2009 | 09:32 PM
engifineer's Avatar
There is a thread on it by bluesciontc over on yoursciontc.com.
A zpi kit for it wouldnt be much use since there is no ZPI any more
B_Real45's Avatar
A kit? I'll sell you a tube of JB Weld and call it my Balance Shaft Removal Kit.
I'll also include a free tube of RTV for your oil pan. Interested?
Old Jan 21, 2009 | 09:39 PM
engifineer's Avatar
I cant locate blues post, but as mentioned, you remove the shafts and you plug the oil passage. Tap the hole for a bolt, insert bolt and apply something to hold the bolt in place for good, like JB weld or loc-tite (on the threads in that case).
Old Jan 21, 2009 | 10:04 PM
g2autosports's Avatar
Rick has done it aka: raamaudio, look him up, he's very knowledgeable.
Old Jan 21, 2009 | 10:38 PM
KCTTC's Avatar
I'm currently making a balance shaft eliminator kit for the 2az.
They will be available for under $100.00 w/ dyno proven results.
Thanks,
Jeremy
sstracing.com
Old Jan 21, 2009 | 10:57 PM
nodsetse's Avatar
I just did a search on Balance Shafts and found all the info anyone could want. There were several threads, more than one person has done it, there are how-to's posted along with pics...so SEARCH people!
Old Jan 21, 2009 | 10:58 PM
Music City Scions
Bah....I will just wait till I pick up the Ptuning built motor. It comes with the balance shafts removed.
Old Jan 21, 2009 | 11:01 PM
Music City Scions
Could have just posted the link...
Old Jan 21, 2009 | 11:11 PM
nodsetse's Avatar
Which one?
The point was, this topic is done. If people would search first, this thread wouldn't exist.
Old Jan 21, 2009 | 11:47 PM
Music City Scions
^^Link that answers the question duh.
Old Jan 22, 2009 | 12:19 AM
tCb00b's Avatar
This post? http://www.yoursciontc.com/forums/in...=balance+shaft
