Balance Shaft Removal
I'm looking for info from people who have done this successfully.
Removing the oil pan, there is another cover that contains the two balance shafts. Removing this cover I can see a gear on my crank shaft that drives the balance shafts. How did you plug or cover the oil jet for the Balance shaft bearing? Also, I only see one oil jet and I can follow the oil path to both shaft bearings, am I missing another one? So far, I can see two options: 1. Drill and tap the oil jet to plug it. 2. Fabricate a block off plate that uses the stock bolt pattern for the shaft cover. Is one way preferable to another? P.S. The bottom end was balanced already so I can not removed the balance gear from the crank (Grrr) so now I'm stuck with that extra weight. Thanks! AJ |
ZPI has done it :lol:
Why dont you call up the shop, and ask them :rofl: |
AJ, I was gonna do this when I built my motor but I heard mixed ideas about this. I heard the vibration was horrible for only gaining like 10whp
Why dont you call up the shop, and ask them :rofl: They promised a kit 4 months ago but never delivered... Sound familiar? Balance Shaft removal kit? 4 months late and counting. Motor Mounts? I think that one is over a year late and counting. Stage 2? Well, I took care of that one for them. Engine Air Diffuser? That one was at least 3 months late. 02 simulator? That POS never worked and it took them 6 months to stop selling it for $100 The list goes on and on... You know, sometimes you act like a Republican... oh wait, YOU ARE! :P |
I was hoping that someone might have completed this already and could answer my questions or provide more insight. Keep in mind that my motor was balance without the shafts so I definitely don't need them, I only need to plug the oil hole so I don't loose oil pressure. |
Why dont you call up the shop, and ask them :rofl: They promised a kit 4 months ago but never delivered... Sound familiar? Balance Shaft removal kit? 4 months late and counting. Motor Mounts? I think that one is over a year late and counting. Stage 2? Well, I took care of that one for them. Engine Air Diffuser? That one was at least 3 months late. 02 simulator? That POS never worked and it took them 6 months to stop selling it for $100 The list goes on and on... You know, sometimes you act like a Republican... oh wait, YOU ARE! :P CHILL OUT! And yes, i am REPUBLICAN !!!!!!!!! |
I know you were joking, but you need to understand that if you and I are going to be friendly you need to NOT blindly talk about ZPI products that DON'T EXIST. They do that enough for themselves ;)
IF they had a product that I needed, I would surely purchase it from them, but if I have a choice... Not so much! |
I would also like any info on how to do this.
-Jeremy |
I would also like any info on how to do this. -Jeremy Regards- Todd |
:D Email sent. I also tried to call your contact number but got a strange voicemail LOL, nice ring back song though :D
I also tried to call your contact number but got a strange voicemail LOL, nice ring back song though Wasn't mine..got to check that. I am off to the track(roadcourse) with one of the TC's...so it will be a bit later for a response to that email. Regards- Todd |
Ok, this is where I called...
Contact Us Why Industries, llc PO Box 50281 Mesa, AZ 85208 Ph. 480-254-1805 Fax 480-380-6949 |
Ok, this is where I called... Contact Us Why Industries, llc PO Box 50281 Mesa, AZ 85208 Ph. 480-254-1805 Fax 480-380-6949 Anyways short break from the track. Get you your info shortly. Regards- Todd |
I thought you sounded a "little" young LMAO!!!!
Would be a nice to know type item if others are already doing it as my motor is in progress and I planned to remove them anyways. If it is not posted in the open, no biggie, will just take a little more time for me to do it my way *LOL* Also it is not about the hp gain, it is about the rotational mass removed. Same effect as a light flywheel, no mega hp gain, but 1st and 2nd gear pull even harder and throttle responce feels micho better.
Originally Posted by TurboToyotas
never got the email Todd. Let me know. Regards- Todd |
todd holla at me when u got free time
Got tied up last night, my apologies.
PM back at you. |
