Balance Shaft Removal
I'm looking for info from people who have done this successfully.
Removing the oil pan, there is another cover that contains the two balance shafts. Removing this cover I can see a gear on my crank shaft that drives the balance shafts.
How did you plug or cover the oil jet for the Balance shaft bearing? Also, I only see one oil jet and I can follow the oil path to both shaft bearings, am I missing another one?
So far, I can see two options:
1. Drill and tap the oil jet to plug it.
2. Fabricate a block off plate that uses the stock bolt pattern for the shaft cover.
Is one way preferable to another?
P.S. The bottom end was balanced already so I can not removed the balance gear from the crank (Grrr) so now I'm stuck with that extra weight.
Thanks!
AJ
Thanks!
AJ
Originally Posted by Whocares05050
ZPI has done it
Why dont you call up the shop, and ask them
They promised a kit 4 months ago but never delivered...
Sound familiar?
Balance Shaft removal kit? 4 months late and counting.
Motor Mounts? I think that one is over a year late and counting.
Stage 2? Well, I took care of that one for them.
Engine Air Diffuser? That one was at least 3 months late.
02 simulator? That POS never worked and it took them 6 months to stop selling it for $100
The list goes on and on... You know, sometimes you act like a Republican... oh wait, YOU ARE!
Originally Posted by 318_tC
AJ, I was gonna do this when I built my motor but I heard mixed ideas about this. I heard the vibration was horrible for only gaining like 10whp
I was hoping that someone might have completed this already and could answer my questions or provide more insight.
Keep in mind that my motor was balance without the shafts so I definitely don't need them, I only need to plug the oil hole so I don't loose oil pressure.
ZPI has done it
Sound familiar?
CHILL OUT!
And yes, i am REPUBLICAN !!!!!!!!!
I know you were joking, but you need to understand that if you and I are going to be friendly you need to NOT blindly talk about ZPI products that DON'T EXIST. They do that enough for themselves ;)
IF they had a product that I needed, I would surely purchase it from them, but if I have a choice... Not so much!
I would also like any info on how to do this.
-Jeremy
-Jeremy
Regards-
Todd
I also tried to call your contact number but got a strange voicemail LOL, nice ring back song though
Wasn't mine..got to check that.
I am off to the track(roadcourse) with one of the TC's...so it will be a bit later for a response to that email.
Regards-
Todd
Ok, this is where I called...
Contact Us
Why Industries, llc
PO Box 50281
Mesa, AZ 85208
Ph. 480-254-1805
Fax 480-380-6949
Contact Us
Why Industries, llc
PO Box 50281
Mesa, AZ 85208
Ph. 480-254-1805
Fax 480-380-6949
Anyways short break from the track. Get you your info shortly.
Regards-
Todd
Would be a nice to know type item if others are already doing it as my motor is in progress and I planned to remove them anyways. If it is not posted in the open, no biggie, will just take a little more time for me to do it my way *LOL* Also it is not about the hp gain, it is about the rotational mass removed. Same effect as a light flywheel, no mega hp gain, but 1st and 2nd gear pull even harder and throttle responce feels micho better.
Originally Posted by TurboToyotas
