base map car wont start....
You can tell what kind of injectors they are by checking the resistance of the injectors. High resistance (I think greater than 8 ohms) is saturated injectors and peak and hold injectors are low resistance (I think less than 3 ohms). I believe the Scion tC is saturated injectors.
if its sold specific for the tc they should be high impendance (saturated) should be 12 ohms.. try resetting your ecu and erase all fuel trims, it might allow you to start as it relearns and starts new fuel trims..
oh does it try to start after you crank and then stalls?
Yeah you run the risk of frying stuff. Did the guy say they were for a tC?
You can try figuring out how to set it up on your own, its not crazy hard to make it work, but BE CAREFUL.
I got them from silverbullet89 he ordered them from decendant...I'm prEtty sure they didnT mess that up and hope these r the right injectors...I'll give it another go toniight or tomorrow....I'll also check the injectors for a serial number or part number and call rc...
i checked the injectors they r rc sl9-550 they r saturated so i did get the right ones..my problem has to be in the damn basemap.....any one out there use the base map on a 07+tc??
i have not the slightest clue why this wont work lol i just want to tune my car already!!!!!
it just doesnt work man two different cars two different ecu's....
have you thought about placing the stock injectors back in the car, unplugging the emanage, and then starting the car?? that will at least allow you to isolate whether your issue is the emanage or the ECU. My car had the same problem, but i wasn't using the emanage.
Make sure you ONLY start it like that, do NOT drive it. Thats for the sole purpose of isolating some of the issues.
Yea my car is a 08 I had a feeling it might be the base map. So where r u other guys getting basemaps for the 07+ emanate blue?
As for firing none what's so ever....I have the 1 step colder NGk plugs and when I drive it as stage 0 it idles perfect.
Can the tuner tune my car if it won't even start?lol
its the tuners responsibility to make a map from scratch....
drive it to him with the emanage on bypass...call dezod or someone to help u put it in bypass mode and then the tuner will take it from there
