Big 16g turbo question
Old Mar 2, 2013 | 12:25 PM
bcp06tc's Avatar
Default Big 16g turbo question
Hey, i just bout a used mitsu turbo, I plan on getting it rebuilt. I just had a question. What is this hole for?
It's already been changed from internal to external wastegate. Pretty much a zpi setup. I have looked at other people's pics with the same setup and it looks like their hole here is open as well I just want to make sure. Thanks.
Old Mar 2, 2013 | 12:26 PM
bcp06tc's Avatar
And its not for oil, both of those fittings are already i turbo
Old Mar 2, 2013 | 06:42 PM
BadDudeTC3's Avatar
Mitsu's usually have oil and water cooled turbos so that could be what the other opening is for. Looks like they plugged the water drain opening.
Old Mar 2, 2013 | 11:34 PM
BlackKnight's Avatar
Music City Scions
X2 on water ports
Sent from my SGH-T999 using Tapatalk 2
Old Mar 3, 2013 | 06:07 PM
bcp06tc's Avatar
So it's fine for that hole to be open then? It won't affect the turbo during use?
Old Mar 3, 2013 | 11:35 PM
BadDudeTC3's Avatar
Well.....one of my best friends is a DSM guy and just told me a story of how his turbo blew because he didn't hook up the water line thinking it would be ok to just have the oil going through it only. When I saw your post I asked him about that and he advised have a connection for the water port also.
Old Mar 4, 2013 | 01:59 AM
sofTCheese's Avatar
i ran the 16G for a year with out the water port blocked off and it was fine now i changed the compressor housing to a tdo6 20G and its still good i drive the car everyday!
Old Mar 4, 2013 | 12:13 PM
bcp06tc's Avatar
thanks man, thats what i thought from all of the pictures ive seen of these turbos they are not blocked off. When i go get it rebuilt i will talk to them about it as well. but thanks for everyones input!
Old Mar 4, 2013 | 02:38 PM
BadDudeTC3's Avatar
You also have to keep in mind that what we consider higher boost....16-20 psi is baby boost for a DSM. So if you're not running higher boost I think you'll be fine. To each is own....my outlook is that particular turbo is designed to use both oil/water cooling so why not use it and optimize cooling.
Brammi
Nov 13, 2016 03:46 AM
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
scioninla
14
Oct 18, 2003 03:46 AM
