boost controller
Originally Posted by zer0
Originally Posted by yamaha16bw
I just change my wastegate spring or shim it. Takes 5 mintues and less boost spikes.
But I have the TurboXS MBC, its cheap and effective.
So you cant adjust internal wastegates? Ive never worked with on before so I wouldnt know.
I am personally going to be going with a Turbo XS dual stage boost controller. 2 stages of boost at the flip of a switch. Keep the stock wastegate spring as low boost and 3-4lbs higher as high boost. Simple design and hook up. 2 manual boost controllers toggled between the 2 by a simple switch:
Originally Posted by DaGreat1
how much do they cost?
Wastegate springs will run you only $40 and you can get any lb spring you want from dezod from 3psi all the way up to 20+:
http://www.dezod.com/pd_tial_wastegate.cfm
(given you're using a 38mm tial WG)
MBC's will run you anywhere from $80-$100
http://www.dezod.com/cat_manual.cfm
I personally would used this MBC http://www.boostcontroller.com/index...26category%3D4.
If you are on a budget and fairly mechanically inclined then you could try this DIY MBC http://www.geocities.com/chmwatson/FAQs/mbc.html.
Also you can adjust the MBC yourself. With a MBC things can get hairy so I would not recommend you messing with one unless you know what you are doing and understand how a MBC works and how easy it is to mess up you engine.
im fixin to goto a dual stage boost controller cause of this ____in transmission. I wanna run 14lbs but I cant get off the line with 14lbs i just hit full boost and pop off rev limiter. ill run 7 then flip to high, BAM!
I used a SRP MBC $15.00. I set it to about 10 psi in the summer and disconnect it during the winter to maintain about a 11.5 afr all year round. I'm still on the Turbonetics Unichip stock tune and it runs great. If you go with a MBC be very careful with the inital settings.
"The Turbosmart Single Stage Boost Control Valve Switch allows you to switch between two boost levels from inside the cabin, using a "Rocket Launcher Switch".
The low boost setting is the "stock" boost level determined by your car's wastegate actuator.
The high boost setting is fully adjustable and uses the same detent system as the Turbosmart "boost tee", which makes adjustment easy and holds your desired adjustment... just set it and let go.
And, it also utilizes the same unique ball and spring design to bring boost on faster. The wastegate will not "see" any boost signal before your dialed-in bost level is achieved. The result is faster spool-up and more horsepower sooner!
Included from the manufacturer are: instructions, Rocket Launcher Switch, fitting hardware, and mounting bracket"
And it's even cheaper too!
To answer your question, you can switch between the 2 settings anytime anywhere from inside your car. Even at full boost. Say you're on the street and your WOT at full boost on the wastegate setting, you could switch on the fly and boost over to your high setting at the flip of a switch, and even switch back! Just be sure you have a custom tune for high boost and maybe even a lb or 2 over incase of surge if you turn using the greddy presure sensor.
I love the Blitz SBC Spec-S. That controller was a single solenoid wth 4 stages, all digital, with peak hold, and scramble capabilities. Plus it'll eliminate any boost spike common with some inexpensive single stage MBCs out there.
Yes it's more money. But it works time after time and I didn't have to worry about my motor
