Boost Creeping
I am having a little trouble with the boost on my car creeping up in 3rd gear it got real high at one point almost 13psi and almost KAPOW!! (stock computer). I cut the softest spring that comes with the waste gate and it boost around 7psi which is what I want for now, but then it creeps in 3rd. Anyone else ever have any problems..I have a turbonetics evolution waste gate and I am going to change it to a TIAL 38mm to see it will make any difference. I wonder if it is because I have the waste gate plumbed back into the downpipe?
Originally Posted by Rasta
Originally Posted by paul_dezod
The evolution and deltagate gates are notorious for creep from past experience.
http://dezod.com/pd_tial.cfm
Originally Posted by zer0
its the 3" exhaust...
On a T25 turbo DSM running a 3" downpipe (apexi N1 for example), you get boost creep. You need to either port or change the o2 housing to fix this issue.
Rastas running a T4 exhaust housing, so it's not that in this case, but seems to be the wastegate. Hopefully switching out to a nice looking TiAL unit fixes the problem.
Man I changed the wastegate to a TIAL 38mm with a .5bar spring and it goes right up to .8bar any Ideas anyone. The wastegate is in a good place do you think it is the size of the Turbo?
Then maybe it is the 3" pipe. I have TIAL as well, and never experienced boost creep. I'm running the ZPI exhaust/S-pipe which is 2.5 all the way through.
What size turbo are you running?
