Boost Gauge Problem... Question
I just installed an autometer phantom boost gauge on my SC tC. At Idle, I'm reading 20-25mg Hg..... The thing is that it stays in vacuum, between 0-15mg Hg, while im at part throttle, and only goes into boost at WOT. I have the NST 9.5 psi pully and I only saw about 8psi....
What could the problem be?
I thought the car would be in boost at part throttle too.
could it be as simple as a leak in the boost gauge fittings?
Thanks
- Dante
Thanks
- Dante
Looks IDENTICAL to my setup.... 20-25 at idle and then climbs a bit and starting at ~2600, climbs past 0 and then up to 6 (until my WG dumps, then just stays at 6) with the S/C, I'd think you'd get a linear transition up through the RPM range.
That's with an Autopower manual boost gauge....
It is a linear transition, but it's only up to about 8psi and it doesn't build boost under part throttle...... even though I can hear the SC spooling.
If I accelerate at about 50% throttle, I'l build about 1-2psi throughout the entire RPM Range from about 2500+rpm
Is that normal?
- Dante
Is that normal?
- Dante
Well I'm turbo and that sounds just like mine. I can hear the turbo spool but its still in VAC. I would worry about it. You should right at -20 at idle. I get about -24ish when I let off the gas while moving.
Originally Posted by dachmo
Originally Posted by yamaha16bw
...... I would worry about it......
You have a few possiblities. One you have a vaccum leak causing incorrect readings. Two you have not switched out the stock bypass valve and have boost leak. Three the gauge has a leak in the line somewhere. Four you have a belt slip problem. All of these are possiblities. As for only seeing 1-2lbs of boost. That is pretty normal. I see about 2.5 lbs until about 5k then it will start to go higher. I only see 9.5 right at redline.
With the supercharger boost is a relationship between RPM and how much the throttle is open. Even at partial throttle I think the bypass valve is being used so therefore you will not get as much air into the engine. You should only see 9.5 psi at Max rpm while at WOT.
I'd say your setup is normal. It depends on where you tap your vacuum line. OuterHeaven is right though, the bypass valve is doing that due to your engine's load and throttle position. When you open it up, the TB opens and all the air can finally rush in, at the boost it needs to be at. You MAY have a small boost leak somewhere or a belt slip if you're actually supposed to hit the 9.5. Sometimes the gauges are a little off too so keep that in mind.
I will put my experience in.
I am running the 9.5pulley as well and have an autometer boost gauge. EVERYTHING IS FINE WITH YOUR SETUP!! You will only see boost if you are pushing it hard. You can easily drive the car a few hundred miles without ever seeing boost. Its awesome because it helps with gas milage. No boost, no extra gas!!
The way mine seams to be. No matter how low the RPMS are, if I floor it it will hit about 2 psi instantly, then build from there and hit 9.5 right before shifting.
Dont worry everything is fine!
oh just saw you arent seeing the full 9.5psi.
I would say, the gauge is off, or you have a boost leak, or your belt is slipping.
Did you change the belt with the pulley?
If you are using the stock BPV *OR* the 110 Sport, you'll leak boost.
Been there, Done that, Wrote the 'for dummies' book.
Get the Forge, put the stiffest spring in, use the 2 shims, install it, problem solved.
damn.... I thought I'd be fine with the 110sport....
I'm definately only seeing 8psi at redline so I think maybe it's time for anew BPV...
Thanks
Thanks
bootlgr
Jan 26, 2016 01:22 AM
my06tc
Jun 25, 2015 12:18 AM
mattjk
121
Dec 22, 2004 10:49 AM
