Buyers Guide: Scion tC Forced Induction
https://www.scionlife.com/guts/bg_s_tc_forced.gif
All turbo kits available for the 2005-2006 Scion tC. As of August 2006 there are no kits available for the 2007 Scion tC. There are no pricing listed due to the fact that specials are always ran and it will vary from time to time. Power was not added due to the fact it will vary to your area. Also this will be updated when ever a new mass-produced kit is created. If any of these parts need to be updated please reply to the topic, or use the https://www.scionlife.com/forums/tem.../icon_warn.gif button to let a mod know so we can update accordingly. Want to learn more about turbo kits in general? Please head here: ScionLife Official Turbo FAQ Sheet THIS IS FOR INFORMATION PURPOSE ONLY!!! NO FLAME WARS ARE TO START!! KEEP IT SANE AND KEEP IT ON TOPIC! PLEASE DO NOT REFER SOMONE TO ONE SPECIFIC COMPANY LET A PERSON DECIDE ON THEIR OWN! Dezod-Stage 1 for a/t avaliable for 2005-2007 models www.dezod.com Components: Turbonetics Dezod Spec'd T3/T4 Turbo Stainless Steel Manifold TiAL 38mm Wastegate Charge Piping w/ Intake Dezod Turbo Install Kit (Special to kit to ensure perfect fitment) Stainless Steel downpipe w/ S-Pipe (extra value) HKS SSQV Blow Off Valve 550cc injectors w/ clips Stainless Steel Braided Oil Lines & Oil Pan Fittings Dezod Large Bar & Plate Front MountIntercooler T-Bolts & Couplers *Plug N Play GReddy E-manage w/ a base map B&M Transmission Cooler *Plug and play harness includes main, injector and ignition harnesses Dezod-Stage 1 for m/t avaliable for 2005-2007 models www.dezod.com Components: Turbonetics Dezod Spec'd T3/T4 Turbo Stainless Steel Manifold TiAL 38mm Wastegate Charge Piping w/ Intake Dezod Turbo Install Kit (Special to kit to ensure perfect fitment) Stainless Steel downpipe w/ S-Pipe (extra value) HKS SSQV Blow Off Valve 550cc injectors w/ clips Stainless Steel Braided Oil Lines & Oil Pan Fittings Dezod Large Bar & Plate Front MountIntercooler T-Bolts & Couplers *Plug N Play GReddy E-manage w/ a base map *Plug and play harness includes main, injector and ignition harnesses On Dezod kits each one have an optional lower priced kit with out emanage. Greddy- m/t avaliable for 2005-2006 models www.greddy.com TD05H-18G Type 31V Intercooler Aluminum Intercooler Piping Tubular Turbo Manifold Cat-Delete Downpipe Greddy has 2 optional addons for this package one including 4x 440 inj, programed emanage or 4x 440 inj, programed Ultimate Sound Performance – m/t avaliable for 2005-2006 models URL? SP Top Mount Manifold (jet hot coated black or silver) SP TC GT 32 Turbo (non ball bearing) (polished cold side and coated hot side black or silver) SP Down Pipe (coated black or silver) Tial Waste Gate (7lb spring) Front Mount Kit Intercooler Pipes (powder coated any color) BOV Full SP Fuel System SAFC II (black or silver) Oil Pan Fuel Rail all fuel and oil lines Turbonetics – m/t or a/t 2005-2006(need verification on 2007 models) www.turboneticsinc.com Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E) Spearco Intercooler System Powder-Coated Intercooler Piping Silicone Hose / T-Bolt Clamps Exhaust Manifold - high carbon cast-steel with ceramic coating Fuel / Timing Controller (electronic fuel / timing management system) Fuel Injectors "Evolution" Wastegate Assembly "Raptor" By Pass / Blow Off Valve Assembly Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge Intake System with Air Filter All necessary Hardware, Hoses, and Fittings Free Case of Turbonetics TS-1 Synthetic Motor Oil ZPI - m/t or a/t 2005-2007 models www.zeropointindustries.net Stage 0 - 6 psi EVO III GT Big 16g Tial Wastegate (silver) Stainless charge piping 4 ply couplers Stainless Manifold Pre tapped Oil pan All fuel and timing tuning already complete Comes with new oil pan making it a true bolt on kit Polished piping Stage 1 – EVO III GT Big 16g Tial Wastegate Tial BOV Stainless Intercooler piping Precision Turbo intercooler with cast end tanks Pre tapped oil pan Pre tuned Emanage 550cc RC injectors Stainless Manifold 4 ply couplers Treadstone Scion Tc Turbo kit m/t 2005-2007 models http://www.treadstoneperformance.com...ct.phtml?p=238 Brand new custom spec T-Series Garrett turbocharger Turbonetics Evolution Wastegate Greddy Type RS Blow Off Valve Super efficient front mount Bar & Plate Intercooler Performance Spark Plugs Fuel Upgrade Racing Cast Iron Exhaust Manifold Polished aluminum piping with Silicone and T-bolts aerospace oil drain and feedline. High flow air filter Precision machined velocity stack MAF adapter |
wow.. nice to know that dezod makes a turbo for autos, and it comes with transmission cooler. :clap:
good write up |
turbo kits
Do you really think turbo'ing an automatic is really worth it ??
isn't there alot of turbo LAG? |
You forgot Turbonetics tuned PnP Unichip :P
Re: turbo kits
Re: turbo kits
Re: turbo kits
Originally Posted by zer0
https://www.scionlife.com/parts/?sub=31
Petey you should update that.. |
you forgot the add ons for the Sound Performance kit.
Ball bearing turbo upgrade Stainless braided fuel line upgrade kit comes standard with Turbo XS BOV Ask Parts_Pimp, he has more details and may have added some options. |
Re: turbo kits
Re: turbo kits
Re: turbo kits
Turbo Lag....WHERE? :P
yea i love my a/t turbo :love:
turbo kits
so for example with the dezod kit...what is the TOTAL HP gain?
Re: turbo kits
5 Speed on 8 PSI is about 100whp and TQ. (240-260whp & 255-265wtq on 8 PSI have been the varied results based upon tuning and the environment) |
Petey you should update that.. lol Oh, the irony. :lalala: |
