Can't find a tune HELP!!
Okay guys I really need help. I just installed my supercharger and it came with a ecu for 07-10 and I have an 06. I called my local dealerships and nobody seems to have the reflash tool to install a new map on my stock one. The one for the 08 only has 4 plugs and mine has 5. Please help!!!!
You can't just swap ECU's with any 05-06 tC out there, you need the proper part # for your car. go to Toyodiy.com and put your vin in and see which ECU part # comes up. There will be like four or five i believe when I needed a used stock ECU for my tC going from S/C to turbo.
Make sure the part number matches what it says your VIN needs or you might end up wasting money for an ECU you can't use.
Honestly, just get a piggyback ECU and find a good tuner. You'll probably have better WHP results if you do.
my06tc
Jun 25, 2015 12:18 AM
TheTripleC
Jan 4, 2015 06:46 PM
