car stalled now rough idle (any advice)
im thinking bent valve, or hole burnt through a valve. pop off the turbo and mani and look through the exhaust port on the suspect cylinder. rotate the crank as needed to get a look at the exhaust valves. if your problem is on the exhaust side then you'll be sure to see it.
it has to do with the MAF sensor. i have an Apexi SAFC2 and it has a setting called Dec. Air (decelerating air), and it allows you to change what your MAF is actually telling your ECU, allowing you to run a atmosphereic BOV, otherwise you would have to run a recirculating BOV to keep from having a stall after you let out of the gas.
also will post results next week after x-mas. Every one have a MERRY CHRISTMAS and thanks for the help. and big mike i will be contacting u on i figure out were I'm losing compression. so i can drop off the machine lol
I know I'm a little late but have you checked your injectors? I had the same sound when 2 of my injectors wouldn't plug in properly.
Sent from my ADR6300 using Tapatalk
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
