CarbonXe is boosted. 287.2/272
Old Oct 10, 2008 | 10:52 PM
  #401
crush02342002's Avatar
just lookin out for a brother...lol
Old Oct 10, 2008 | 10:56 PM
  #402
CarbonXe's Avatar
Yeah I know, it's not that low on it.
Old Oct 10, 2008 | 10:57 PM
  #403
Ace83's Avatar
Ronin Scion
yeah it looks kinda low, though on our pan we really cant put it too high.. just be careful your oil wont back up to the turbo.. as long as it doesnt leak it should work
Old Oct 10, 2008 | 11:07 PM
  #404
i got an idea, if it is too low just run less oil
i know it wasnt that funny
Old Oct 17, 2008 | 01:54 PM
  #405
CarbonXe's Avatar
PAULLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
You have a PM .
I might be delaying my turbo install, depends on what the ____ this noise is. I began hearing a knocking/(sometimes)metal to metal clunking noise yesterday coming from the rear end under the car. Gonna check it out tonight, if it's nothing to do with my sway/exhaust, I'm going to bring it to the dealer and just have them take care of it...
Old Oct 17, 2008 | 03:00 PM
  #406
ippskidder's Avatar
1UP Crew
You have a PM .
I might be delaying my turbo install, depends on what the flip this noise is. I began hearing a knocking/(sometimes)metal to metal clunking noise yesterday coming from the rear end under the car. Gonna check it out tonight, if it's nothing to do with my sway/exhaust, I'm going to bring it to the dealer and just have them take care of it...
Could be a the bolts that go on the sway bar bushing bracket thingy, came loose.
Or the bolts on the endlinks.
Happened to me once or twice after the hotchkis went in. I put some major torqueage and some threadlocker. Its fine now ^^
Old Oct 17, 2008 | 03:22 PM
  #407
CarbonXe's Avatar
I checked the end links on the sway bar, and it wasn't that.
Did it make the noise when you turned also? Mine only makes the noise when I hit bumps...something is loose and bouncing around. As long as I get this fixed before next week, I'll be doing my install next weekend (weather permitting).
Old Oct 19, 2008 | 03:39 PM
  #408
ippskidder's Avatar
1UP Crew
Are you sure you just don't have a bowling ball in the trunk??? =D
Old Oct 19, 2008 | 11:09 PM
  #409
CarbonXe's Avatar
lol, nothing in the trunk...
Had the car jacked up, we smacked everything with a rubber mallet, nothing, shook everything around, nothing... Can't figure it out . Even over the slightest bumps, it knocks. It sounds like something metal is swinging and smacking another metal part. I think I'm going to take it into the dealer.
Old Oct 19, 2008 | 11:23 PM
  #410
aen's Avatar
aen
bump stops rubbed through and are knocking on the frame?
Old Oct 20, 2008 | 04:56 PM
  #411
CarbonXe's Avatar
Still haven't pin pointed the noise, but I think it might actually be my exhaust hitting my FRONT sway bar. I've had my mid pipe in backwards (straight muffler section of the PTuning exhaust), and I swapped it around the other day when I was trying to find this noise. When I swapped it around, I noticed that the small elbow piece (needed to connect the exhaust to the stock s-pipe) was sitting rather close to my sway bar and the sway bar was scuffed a bit (could have been when I tried to install my PTuning S-Pipe). The problem with that elbow piece, is that it has a large flange on it, to match up to the stock s-pipe, with the 3" s-pipe, it will connect at the midpipe and delete the elbow, resulting in more clearance. I'm going to wrap the sway bar with a towel or something tonight...if that solves the problem, turbo install this weekend (weather permitting and assuming I get my parts). If not...removing the rear bumper, tails, etc to see if I can hear it better/pinpoint it.
I've eliminated a few issues so far. My HID ballast was bouncing around, as one of the zip ties broke, fixed that. The resistor box (or w/e the ____ it is) for my Anzo tails (3M'd to the inside of my fender) fell and was bouncing around, fixed that. Smacked almost every component under the car in the back, nothing was replicating the noise, nothing was coming even close.
One thing that is pointing me away from suspension components, is the fact that it doesn't 'only' do it over bumps. I've hit some things pretty hard, and it didn't make the noise, and it's made it just backing out of my driveway (steep decline of about 1 foot, resulting in no rough jerking, just frame twist). That and it does it when I downshift sometimes. It sounds a lot like it's something large, swinging into something metal.
Actually, I don't think I'm going to get my parts in time for this weekend. If I get them thur/fri, I won't do the install. I want to have a few days of prep time, to make sure I have everything, make sure everything will fit properly, etc. I still need to get some vacuum hoses and a clamp.
Old Oct 20, 2008 | 06:15 PM
  #412
java09's Avatar
good luck!
Old Oct 20, 2008 | 06:31 PM
  #413
CarbonXe's Avatar
Bleh. I'll be happy when this damn car is finished. Only took 10 months and $8500 (only actually paid about $2500 lolz), but it'll finally be finished by the end of next month/beginning of December.
Old Oct 20, 2008 | 06:37 PM
  #414
coryjames's Avatar
my car wont be done any time ssoon lol maybe late winter spring for sure lol lets just say all you tc guys better step it up lol
Old Oct 20, 2008 | 06:42 PM
  #415
CarbonXe's Avatar
Well that's the thing. My car will be fiinshed. I could potentially do more, but I'm not. I'm finished with modding it once I get the turbo on and pick up my two new other parts. Gotta start saving up for my next car, because modding that is going to be even more expensive...Just to get the wheels/tires/fenders to fit the rear wheels, is going to cost about $6,000. And those are OEM wheels.
Old Oct 20, 2008 | 08:02 PM
  #416
aen's Avatar
aen
nono, cory, you got it twisted.
YOU better step up.
Old Oct 20, 2008 | 08:39 PM
  #417
ippskidder's Avatar
1UP Crew
I can't wait to finish mine. I'm almost close to complete.
I had bigger plans for it, but the wheel spins is bad enough as it is. No reason to make it worse than that, LMAO!
Mishimoto radiator install, some defi sensor replacements, new front windshield (mine is cracked), vrd grills, '08 headlights, 2 hid replacement ballasts, replacement a-pillar, some white interior lighting, and done for a loooooooooooong time.
Old Oct 20, 2008 | 10:24 PM
  #418
all4degame's Avatar
Good luck with getting everything done. After I throw my turbo on I'm calling it quits with the tC. What are you thinking about for the next car? I'm thinking about picking up a 135i. I've seen a couple around town and they are pretty sexy.
Old Oct 21, 2008 | 03:16 AM
  #419
TurboToyotas's Avatar
We'll see after you have boost.
Regards-
Todd
Old Oct 21, 2008 | 05:18 AM
  #420
ippskidder's Avatar
1UP Crew
The 135i is hotttttt.
There is an ecu flash, that brings up the whp on those ^^
Price isn't so bad on the flash.
But every other mod i've seen for it is really expensive >.<
