CarbonXe is boosted. 287.2/272
Old Mar 8, 2009 | 06:49 PM
  #1881
CarbonXe's Avatar
Originally Posted by crush02342002
afr looks a little jumpy but not much at all.....mine looked pretty smooth until full boost at which it jumps quit a bit...it seems to be an on off thing for me so idk. power looks real smooth...me likey
That's because of the dyno. It shows the real value. Other dyno's will smooth the graph out to make it look like it's more stable.
Toan showed me how other dyno's show the AFR, and when he changed some crap in the software, the line was perfectly straight across. It's basically a way for a tuner to get out of properly tuning the vehicle. Same thing as the correction factor, they can make that dyno read whatever numbers they want it to read. That's exactly why I went to PTuning and not RIPPmods. Toan took his time with my tune, he hit every load point possible, got the optimal timing, etc. If I went to RIPPmods in NY, they would have thrown on a base tune and printed out the results that I said I wanted.
Old Mar 8, 2009 | 06:50 PM
  #1882
CarbonXe's Avatar
Originally Posted by tC_2NeR
Btw Jon u could adjust the clutch pedal to engage higher..like stock
Shoot tcpete a pm
I know, but I'm not going to change it...I'm used to it already.
Old Mar 8, 2009 | 06:53 PM
  #1883
crush02342002's Avatar
did you kill the car a couple a times with that new clutch?...lol
Old Mar 8, 2009 | 06:57 PM
  #1884
brett561tc's Avatar
so when can we expect to see some track numbers?
  #1885
CarbonXe's Avatar
I opened it up everytime I came out of the toll plazas on the way home .
Just filled up the car...on the way down on my street tune and on 18's, I got 27MPG. On the way home, with more WOT pulls and a lot more power, I got 32MPG. If I stayed out of boost completely, I probably would have got about 35-37MPG.
Old Mar 8, 2009 | 06:58 PM
  #1886
CarbonXe's Avatar
Prob never. If anything, I'm going to Auto-X it this summer.
Old Mar 8, 2009 | 07:07 PM
  #1887
huslindan's Avatar
just track it once you no you wanna see what you can get lol......
Old Mar 8, 2009 | 07:17 PM
  #1888
brett561tc's Avatar
thats like having a shotgun, and saying your going to beat someone to death with it. use it what it was made for.
i just miss the days on scionlife where it was automatic that after a good new tune, you were takin your car to the good old 1/4 mile dyno.
Old Mar 8, 2009 | 09:13 PM
  #1889
tC_2NeR's Avatar
I know Ptuning did a good job but my only question is why are the number sorta low?
is it just me?
i was expecting 310+whp
it looks like 9psi
or is it that non corrected stuff
Old Mar 8, 2009 | 09:27 PM
  #1890
CarbonXe's Avatar
I can go to a DynoJet and have 330whp, but I won't because that's not how much I'm making.
Old Mar 8, 2009 | 09:48 PM
  #1891
brett561tc's Avatar
people get way too bent out of shape over dyno numbers. they really dont mean that much. lap times, or 1/4 mile times mean alot more to me.
Old Mar 8, 2009 | 09:49 PM
  #1892
its about how it feels and how many honda's asses you kick
j/k i got nothing against hondas i just like talking crap
Old Mar 8, 2009 | 09:52 PM
  #1893
CarbonXe's Avatar
Buttdyno FTW!
Old Mar 8, 2009 | 09:56 PM
  #1894
dave2610's Avatar
QFT
Old Mar 8, 2009 | 09:58 PM
  #1895
CarbonXe's Avatar
is it just me?
it looks like 9psi
Basically, you can go to Dezod and get the car tuned or you can go to PTuning to have it tuned. If they both make the same fuel and ignition maps, the car will make the exact same amount of power. The only difference, is that the dyno at Dezod will give you a higher number than the dyno at PTuning. Personally, I'd rather know what my real numbers are than think I have 800hp when I only have 300.
There are only two factors when it comes to tuning. Ignition and fuel. Yes, elevation and temperature are factors, but that has nothing to do with the actual tuning process.
Old Mar 8, 2009 | 10:18 PM
  #1896
Ace83's Avatar
Ronin Scion
yup 270-280s is about right, are actually good numbers considering the type of dyno used... and its true elevation and ambient temp are the least factors that can affect numbers.. though extreme temp can also limit your tune to a more conservative one, but with an efficient IC that shouldnt be a problem..
Old Mar 8, 2009 | 10:22 PM
  #1897
CarbonXe's Avatar
Actually, temperature plays a huge factor. I was peaking at 276 and we decided to let the car cool down. We just let it sit for about 15-20 mins with the fan blowing on it. After we cooled down the engine bay, I gained another 11WHP.
But that's another reason why I made so much power when I went there in November. It was about 30 outside and the car went straight from being outside to doing the dyno pulls. Plus Toan said my ignition map was close to being perfect. No clue how I pulled that one off.
Old Mar 8, 2009 | 10:55 PM
  #1898
rhythmnsmoke's Avatar
Music City Scions
Great numbers man. Keep up the good work.
Thanks. I'm so glad I finally got all this stuff done. The car feels so much stronger now, it doesn't feel like a cheap, girly import anymore .
Did it grow a pair....
Old Mar 8, 2009 | 11:05 PM
  #1899
Music City Scions
is it just me?
it looks like 9psi
I think Dezod would actually have to get their own dyno first...
95 pages....wow!
Old Mar 8, 2009 | 11:09 PM
  #1900
CarbonXe's Avatar
It's had a pair since I put the turbo on, but now it knows it has a pair
