Check engine light,rough idle after TRD supercharger install
Old Oct 27, 2007 | 04:26 AM
blue_06tC's Avatar
Default Check engine light,rough idle after TRD supercharger install
So I got my tC back today after having the TRD supercharger installed. When I was leaving the dealer I noticed the idle was very rough. It was kinda bouncing up and down between 500-1200 rpms,almost feeling like it was going to stall sometimes but didnt. So I get it home and let it idle for a bit just thinking that maybe the computer needed to "learn" the supercharger. After a couple minutes of rough idling the check engine light came on. The only other mod I have is a Concept G axle back. Is there anyway the exhaust is affecting the supercharger? Im gonna be taking it back to the dealer but just wanted to get some ideas what might be wrong or what are some common things to look for. Help please.
Old Oct 27, 2007 | 04:28 AM
kikcaffine's Avatar
Go to autozone and have them check the code. My car was throwing a P0420 which ment the cat died basically. Its not really detremental to the car aside from you will get crap for fuel economy.
Old Oct 27, 2007 | 01:42 PM
JBodygoneTRD's Avatar
did they flash your ecu? check vacuum lines for leaks. If it was anything like my dealership they didn't tighten down a damn thing.
Old Oct 27, 2007 | 01:45 PM
blue_06tC's Avatar
Just got back from the dealer and it turned out be a vacuum line that blew off next to the throttle body. Phew.. Thanks.
Old Oct 27, 2007 | 02:07 PM
jwaggz82's Avatar
^ and for anybody else having this problem and its not a vac line ..... take the positive wire off your battery for 10min ... then put it back on and let the car idle for 10min ....then drive normal for 20min ..... and you will have a freshly reset ecu (which is a good place to start when you having issues like this).
Old Oct 28, 2007 | 12:31 AM
bsptc27's Avatar
^^ dont you mean the (-) negative cable?
Old Oct 28, 2007 | 01:55 PM
jwaggz82's Avatar
^ I always take the positive off so the negative is on when i put the positive back on (so it grounds w/o issue) - someone correct me if im wrong
Old Oct 28, 2007 | 06:28 PM
megrog2's Avatar
I thought you're supposed to take the neg off to minimize sparking and
possible electrocution.
Old Oct 29, 2007 | 11:39 AM
jwaggz82's Avatar
Well here is the way to jump a car ....and for that ...its by putting the positives on last like you are saying ... so is it the same to reset the ecu?
http://www.carbuyingtips.com/jumpstart.htm
Jordly221
Feb 13, 2019 05:29 PM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
ScionRo
Jan 2, 2015 07:54 PM
hotroddelux
Dec 3, 2014 11:33 PM
