Clutch out Pic up!
is a pos.... make's a werid noise when i press the clutch and then goes away when i let off and i can like feel the clutch spinning when i put my foot on the clutch pedal also i cant shift in a hgh rpm at all always grings or just doesint go i have CC stg4 p puck sprong clutch and 9.5lb fidanza flywheel i think the flywheel is to light thats why i cant shift in high rpm's im gonna get a 12lb flywheel and idea's on a better clutch?im gonna be running 11 psi soon shooting for 300 after i get this clutch shizz figure'd out
I would suggest to check the following:
1. clutch free pedal free play
2. bleed the clutch system
3. you have to remove your transmission to find the actual issue if 1 &2 doesn't work. It sounds like a throwout bearing the OEM or aftermarket ones for the tC's aren't the best. They are not sealed completely.
did you re-use your stock TOB or did you use the one that came with the kit? also try using mt-90 from redline thats what i used and it helped for me. my 4th was always a _____ now its not so bad. try that. worth a try and cheap also.
sounds like what blackknight said...same thing happened to me last month...my tob was shot. first though adjust your freeplay and release point to within spec then if that doesnt fix it bleed lines. if problem is still there drop that hoe
i used the tob that came with the clutchand im useing RP tranny fluid i can get a used flywheel with 100 miles on it for cheap then ima get a new clutch and when i press the clutch in with the car running it sounds like when the ps is low on a car it makes that winding noise thats what im gettin its werid ima get a new one swap the clutch out and im pretty positive the clutch is messed up get CC to warrenty it got any suggestions on a better clutch?
http://www.wesellcarparts.com/store/...idproduct=8720
mayb this one doesint say what stage tho but does say 499lb of torque
